Author Topic: tell me why....  (Read 2082 times)
spoonman
tell me why....
« on: March 13, 2012, 08:00:41 AM »
every couple of months i need to take my tbi off, clean the oil off everything, clean the hose from the silencer box, and clean the hose from the valve cover? is this normal jeep maintenance? my jeep is now my daily driver , so i have to make sure it's running perfect. btw, it's all stock.
Re: tell me why....
« Reply #1 on: March 13, 2012, 08:55:08 AM »
This is not normal.  Try cleaning the CCV system, it may be clogged at the brass fitting at the valve cover.
spoonman
Re: tell me why....
« Reply #2 on: March 13, 2012, 09:06:22 AM »
the brass fitting and hose coming out is part of my bi monthly cleaning.
Re: tell me why....
« Reply #3 on: March 13, 2012, 09:23:30 AM »
Are you cleaning the one from the valve cover to the manifold?
There is another thread right now about a catch can. If nothing else works, that may be the solution for you.
spoonman
Re: tell me why....
« Reply #4 on: March 13, 2012, 10:20:41 AM »
it looks like a catch can is in my future. i clean both of the lines from the valve cover.  thanks for the help. i will be looking up the link for that.
Re: tell me why....
« Reply #5 on: March 13, 2012, 01:53:14 PM »
Make sure you run a wire or drillbit through the small CCV fitting that the plastic line connects to.  I've had mine clogged.
Re: tell me why....
« Reply #6 on: March 13, 2012, 06:19:51 PM »
Glad this topic came up.  I'm putting on the catch can.  But would like to make sure my CCV is working.  Never did pull the fitting off so I'm sure its plugged.
