Author Topic: How do you take the shifter rod off?  (Read 1352 times)
geocachenut
« on: March 13, 2012, 07:05:45 PM »
Just removed the AX-5 trans from the 4 banger....lost 5th gear and the others thump a little.  I removed the shifter by taking the 4 bolts from the top of the tranny off.  I want to know, is there a way to remove just the shifter lever without removing the top cover to the tranny?  It is on a square stud.  Any ideas?
Re: How do you take the shifter rod off?
« Reply #1 on: March 13, 2012, 07:07:38 PM »
I believe it's push down and turn CCW.
Wheezer
« Reply #2 on: March 13, 2012, 10:33:44 PM »
Yup! You push down on the ring at the bottom of the shifter and turn it CCW. Mine was nice and slick with oil and other things so I used a machinists scribe to grip it enough to turn it.
Wheezer
