Author Topic: AxleTech International Motorsports (AIM) and Mopar, Dynatrac Portals  (Read 2900 times)
http://www.dynatrac.com/products/axles/portals.html
Dynatrac has been designing and manufacturing the very best drivetrain components for 4x4 vehicles for over 20 years. They created a revolution in ground clearance with the inception of the ProRock axle housing in 2002. Now, in collaboration with AxleTech International Motorsports (AIM) and Mopar, Dynatrac is pushing the envelope even further with these new American-made portal axles.
So what is the advantage of a portal axle? The gear reduction at the hub moves the axle center line up five inches for increased ground clearance. This is a dramatic change; the equivalent of switching from 35” to 44” tires on your vehicle. Additionally, the geared hub design provides a 1.5:1 gearing reduction through a massive 41 spline axle shaft designed specifically to account for increased torque loads. The nodular iron AIM portal gear boxes contain four 2.25 inch wide 8620 heat treated steel gears: a drive gear, two idler gears, and a gigantic driven gear that keeps the drive direction constant, making them a practical retrofit to traditional axle housings. By multiplying torque at the wheel, less torque is transferred through the driveshafts, transfer case, and other upstream drivetrain components. And a numerically higher gear ratio can also now be used, which results in a larger, stronger pinion gear.
The idea of using portal axles for more ground clearance is not new, however there have been a number of factors that have made them unfeasible… until now. In the past you had to overcome poorly functioning drum brakes, long pinions that result in short driveline lengths, excessive weight, and difficult to source foreign parts when trying to retrofit portal axles to your Jeep or 4x4. Dynatrac has worked closely with AIM and Mopar to address all of these issues (and more) with the introduction of their innovative new portal complete axle assemblies and sub-assembly components.
Axle Comparison   Dynatrac ATI Portal   Unimog 404 Portal
Width   User Selected   69 Inches
Brakes   Wilwood 4 Piston Calipers and Vented Rotors   Drums
Gear Ratio   From 5.31 to 7.17   7.56 Only
Differential   User Selected (Eaton Detroit Locker, ARB Air Locker, etc)   Cable Actuated Locker Only
Spline Count   35 (inner), 41 (outer)   8
Bolt Pattern   Common 8 x 6.5   Rare 6 x 205 mm
Pinion Flange   User Selected (1410, 1350, or 1310)   Torque Tube
Pinion Length   Nex Gen 44- 10.77”, Dana 60-13.28”   19.5 Inches
Suspension Mounting   User Selected (JK, TJ, or custom)   Must be Custom Fabricated
Parts Sourcing   Dynatrac or Most Major Auto Parts Stores for Wear Items   Nearly Impossible in the USA
Origin (Design & Manufacturing)   USA   Germany
Realistically these new portal axles aren’t for everyone. They are not recommended for highway use, and the leverage of the portal design places additional stress on suspension mounting points and control arms. Electronic controls such as ESP and ABS cannot be retained with the portal boxes, as they can with Dynatrac’s traditional ProRock, Pro, and Trail Series axles. There is no provision for a standard parking brake; however a driveline brake at the transfer case can easily be added to address this issue. Final suspension design will be determined by many factors and it is crucial that the suspension design address the added torque and leverage of the portal system. The end user will need to design proper steering and a strong 4-link suspension. Therefore, it’s important that a qualified specialist with fabrication skills and a thorough knowledge of suspensions install it. In short, this isn’t a ‘turn-key’ assembly that fits any application. With the caveats out of the way, it becomes clear that if you require the absolute greatest ground clearance, with gear reduction to overcome the most severe, boulder-strewn trails and obstacles, there is no substitute for Dynatrac and Mopar axles equipped with AIM portal housings.
The portal wheel ends are currently available for king pin steering knuckles and full floating rear Dana 60, Dana 70, and AAM 14-Bolt applications. Dynatrac can provide the AIM portal housings on their proprietary ProRock and Pro-series axle assemblies with suspension brackets for a wide variety of vehicle applications.
We are still very early in the evolution of portal axle systems. As more of these units are tested we’ll have more information regarding suspension and steering design to pass on to the installers. We are continuing work with Mopar and AIM on Jeep Wrangler JKs to refine the system to create a more ‘turn-key’ package. Mopar Performance part numbers P5155670 and P5155671 are available from Dynatrac and your local Dodge/Chrysler/Jeep Dealer. They are specifically designed to fit 2007 and newer Wrangler JK vehicle if used for off-road only purposes. Dynatrac is not only a dealer for Mopar parts and accessories, they are also a supplier of new and unique products to Chrysler and Mopar, with their axle assemblies being prominently featured on popular Mopar Underground vehicles such as the Lower 40, NUKIZER M715, The ImMortal, and the 1320 Dodge Challenger.
In addition to making the made-to-order custom axle assemblies that Dynatrac is famous for, AIM portal boxes and related components will also be available individually from Dynatrac for those who wish to retrofit the portal boxes to their existing axles. “People best know Dynatrac for providing high quality, US-made axle solutions,” explained Dynatrac founder Jim McGean. “The evolution of off road vehicles continues and once again, Dynatrac is in the forefront with the help of industry leaders like AIM and Mopar Performance”
Re: AxleTech International Motorsports (AIM) and Mopar, Dynatrac Portals
« Reply #1 on: April 02, 2012, 06:21:23 PM »
They look good.  How much will they cost?
« Reply #2 on: April 02, 2012, 08:11:11 PM »
Seems cool. I'm guessing this only would be for the rear which doesn't seem all to effective for just one end higher.
« Reply #3 on: April 02, 2012, 08:14:38 PM »
my guess is about $6k, also curious to find out how much
« Reply #4 on: April 02, 2012, 08:18:29 PM »
Way low.
Both together cost $23.5K.  Notice though that they don't recommend street use, which means highways.
« Reply #5 on: April 02, 2012, 08:23:08 PM »
Way low.
huh, what - that's way too much. what market audience are they after, can't imagine selling too many at this price.
« Reply #6 on: April 02, 2012, 08:45:52 PM »
Hardcore Rockcrawler with deep pockets.  Someone who wants to build a buggy and run 40's...
« Reply #7 on: April 02, 2012, 09:50:36 PM »
Lot cheaper to use Unimog axles. Those gear boxes can and will break, the pumkin sits very high so you end up with a very tall rig if you want decent uptravel.
It isn't all roses, this is more for those that got to much money and just have to show off what they got
« Reply #8 on: April 02, 2012, 10:02:40 PM »
do you know if those gearboxes custom (i mean purpose) made or are they used on something else as well? i assume they're custom otherwise you'd see them used regularly but you never know.
« Reply #9 on: April 02, 2012, 11:20:01 PM »
They are made by AIM.  You can see them on their site.  They just attach to your existing axle.
« Reply #10 on: April 02, 2012, 11:42:11 PM »
that is cool.
i looked and there's supposed to be a PDF  (bolt-on conversion brochure) but the link is broken, i wonder how much those go for, i mean it would be way cheaper to get them attached to a pair of D60s, not a weekend job but still can't imagine to get you anywhere close to $24K for front/rear
