Author Topic: Is a rear disk brake conversion worth while?  (Read 5441 times)
Re: Is a rear disk brake conversion worth while?
« Reply #15 on: April 28, 2012, 03:49:47 PM »
You wanted smaller ones? I thought people always go for the bigger ones
I think he is referring to the bolt pattern for the wheels. you have to match what your axles have which is 5x4.5". The zj has the same bolt pattern as the wrangles to though (tj/yj) so it shouldn't be a problem. I ran zj wheels for a few months when i got my yj before the lift and Rubicon wheels so I know the bolt pattern is the same.
« Reply #16 on: April 28, 2012, 04:48:50 PM »
5x4.5 and 5x5.5 is the bolt pattern for the wheels, i looked and ZJ is the same as Wrangler TJ/YJ 5x4.5
