Author Topic: 94 2.5 beginning to backfire...  (Read 1474 times)
geocachenut
« on: April 22, 2012, 06:39:23 PM »
 :'(  Over the winter (I don't drive her in the winter), I had the throttle body bored to 63 MM, changed out the plugs, cap and rotor.  For some reason, when I am getting on the highway (foot to the floor) and changing gears, it has begun to backfire.  I also replaced the exhaust.  Anyone have any ideas what might be going on?
Re: 94 2.5 beginning to backfire...
« Reply #1 on: April 22, 2012, 07:03:19 PM »
what's the plug gap set at? any O2 sensor issues or any codes?
if none of the above my guess it's a leaky injector
« Last Edit: April 22, 2012, 07:04:12 PM by sharpxmen »
« Reply #2 on: April 23, 2012, 08:52:01 AM »
Been thinking on this one if it just started after sitting  there are a couple of things to check.  Moisture in the Ignition system.  Or More like it the fuel has collected Moisture  and this  10% stuff gets is straight out of the Air..
