Author Topic: Gear  (Read 1470 times)
jcrockarell9937
Gear
« on: April 23, 2012, 03:16:27 AM »
Are these the main parts you would need to regear?  (I know you would need someone to put them in)
http://www.quadratec.com/products/52419_91X_A_PG.htm
http://www.quadratec.com/products/52419_92X_PG.htm
Re: Gear
« Reply #1 on: April 23, 2012, 08:24:18 AM »
you need an install kit as well (which contains pinion bearings, pinion and carrier shims, bolts, crush sleeve, pinion nut, marking compound, RTV, pinion seal)
