Author Topic: PSI help  (Read 2372 times)
slazyks
PSI help
« on: May 27, 2012, 06:34:13 PM »
I've got 31/10.5/15 BFG MT AT2 on my tj.  The tire people inflated them to 40 psi.  Today while running Cleghorn I was told I never should have my tires that high and that 28 was good for street.  So I googled it and of course I got a trillion different answers.  Some say 26 some 35 some 32 etc.......  I lowered the pressure down to 35psi (while tire was warm).  BTW the sidewall say's 2270 max load single at 50psi.
What do you all think?
Re: PSI help
« Reply #1 on: May 27, 2012, 06:36:46 PM »
between 28 to 32 should be fine, i run 32psi with 33x12.5x15, imo 40 is really high,
Re: PSI help
« Reply #2 on: May 27, 2012, 07:28:50 PM »
28 to 30 is fine, you can to the chalk line or what ever it's called and see where the tires contact the ground
Re: PSI help
« Reply #3 on: May 27, 2012, 09:30:56 PM »
The Higher pressure is for use on a heavier vehical like a truck.  The Max numbers would be for a loaded truck.
  Our jeeps are really light an d would beat us to death at the Higher Numbers.
slazyks
Re: PSI help
« Reply #4 on: May 28, 2012, 07:47:58 AM »
I'm going to do the chalk test this morning since my wife chose me to be the one to go get a good spot at the park bright and early.  I'm going to drop them to 32psi and check it.  Thanks for the input.
HAPPY MEMORIAL DAY!!!!
Re: PSI help
« Reply #5 on: May 28, 2012, 11:42:04 AM »
It really depends on the tires contact patch.  This will depend on the tire width, wheel width as well as vehicle weight. Wider tires on a narrower wheel will cause the tire to wear like it's over-inflated unless you lower the PSI.  The downside is lower pressure means the tire will ride softer and generate more heat which means wear.
When I was running 35x12.5R15's on 15x8.5's I had to run around 25-27psi to get a even contact patch.  For my 33x10.5R15's on 15x7's I run 35-40psi.  So whoever told you you shouldn't run your tires over 28psi doesn't really know what they're taking about.  It's not a one-size fits all sort of thing.
