Author Topic: Can you repair tailgate hinges on a 98 TJ  (Read 3423 times)
Offline Utwrangler25
  • Newbie
« on: July 24, 2012, 07:01:48 AM »
Anyone know if its possible to repair the tailgate hinges on a 98 TJ or if I have to replace them any suggestions on where to get them. I've already checked Quadratec and 4 wheelparts. Any other suggestions would be appreciated.
Re: Can you repair tailgate hinges on a 98 TJ
« Reply #1 on: July 24, 2012, 07:47:44 AM »
The possibility of repair depends on what is wrong with them. What is wrong with them?
If you decide to repair, you could probably get some from ebay or a junkyard as an alternative to new ones.
Offline VA_YJ
  • Now I need a CJ...
« Reply #2 on: July 24, 2012, 11:34:24 AM »
Another option, get rid of the hinges by installing a drop tailgate kit (like a pickup truck).  SWAG Offroad has a kit for $80 that uses a CJ tailgate or $180 that uses your TJ tailgate.  You can eat your lunch or drink beer while sitting on the tailgate!  :beers:
http://www.swagoffroad.com/
Wheezer
« Reply #3 on: July 24, 2012, 07:27:59 PM »
If you decide to replace your hinges, you might try Wholesalemopar.com.
Wheezer
JohnnyO
« Reply #4 on: August 09, 2012, 08:37:06 AM »
I had ours replaced when I had it painted.  They were very stiff and it took a lot of effort to open the tailgate.  The body shop said that happens to a lot of them and the only option is to replace.  Made sense to me because a bunch of WD-40 hadn't helped.  I got a pair of stainless steel units from 4WD Hardware for about $160 IIRC.  Probably cheaper than an OE set.
They have black powder-coated too.
« Last Edit: August 09, 2012, 08:38:22 AM by JohnnyO »
« Reply #5 on: August 11, 2012, 12:05:00 PM »
I really like that kit; awesome find!  :thumb:
