Author Topic: Opened up the exhaust and the catalic con is empty. Now what?  (Read 5879 times)
Re: Opened up the exhaust and the catalic con is empty. Now what?
« Reply #15 on: August 12, 2012, 01:17:45 PM »
i would at least replace the muffler, uknown if that's the reason but just to make sure, the insides of the cat had to go somewhere so for that matter i would replace both.
« Reply #16 on: August 12, 2012, 01:21:32 PM »
Go to stock by fixing the problem at the source - get the replacement/performance/universal cat. Mechanics, future owners, or you will have less headaches that way. My 2 cents.
This would be my recommendation as well.
Offline andpgud
« Reply #17 on: August 12, 2012, 02:58:46 PM »
I will then get an universal cat along with a new muffler.
What are the specs that the catalyc converter has to have?
« Last Edit: August 12, 2012, 03:08:23 PM by andpgud »
« Reply #18 on: August 12, 2012, 03:23:55 PM »
universal 2.25'' inlet/outlet
« Reply #19 on: August 12, 2012, 05:22:09 PM »
Reason I ask is the old owner could have gutted the cat.
« Reply #20 on: August 19, 2012, 03:28:10 AM »
Plugged fuel filter,, engine goes lean and the cat melts...
And blows out the tail pipe in itty bitty pieces..
My YJ did it twice...
