Author Topic: 4.0L Engine mounts  (Read 1764 times)
4.0L Engine mounts
« on: September 24, 2012, 05:45:34 PM »
Just curious, anyone know if the aluminum brackets that hold the mounts to the block are interchangeable?  I was reading that some people who swap to 4.0L's can get away with reusing their 2.5L engine mounts but they don't really go into it.  I know the actual engine mounts aren't the same as the 4.0L's so you'd have to swap the brackets as well.  Anyone run across this?
Re: 4.0L Engine mounts
« Reply #1 on: September 25, 2012, 02:58:56 AM »
Brown Dog lists their's as being different, but I'm not positive. May just be because their 4.0L mounts use extra bolt holes and the 2.5L doesn't need it. :puzzled: http://browndogindustries.com
I bet Tim there would know.
By the way, I still have my OEM 4.0L brackets minus the fubar mounts.
« Reply #2 on: September 25, 2012, 04:54:10 PM »
I know Brown Dog bought a bunch of the old frame mounts when Chrysler wes liquidating them.  I'm curious since I keep seeing people mention they reused their old mounts and the 2.5L mounts are different.  IIRC, the driver side spacing is around 1/2" wider on the driver mount.  I think the passenger side was slightly smaller as well.
« Reply #3 on: September 28, 2012, 09:21:32 PM »
The passenger side mount is a two piece gadget on mine, the left is not...
The right side has a plate bolted on top that's like a spacer, it broke once
and the dealer had them in stock said it was way common.. Maybe the 4.0 does not need the spacer?
Cheers.
« Reply #4 on: September 28, 2012, 10:25:35 PM »
Cheers.
The 4.0L does not use the spacer and the spacing of the bushing is different.  I'm wonder about using the whole engine mount.  The frame, mount and bracket on a 4.0L.
