Author Topic: Noise  (Read 9625 times)
Re: Noise
« Reply #15 on: September 29, 2012, 12:18:30 AM »
Never done this before... but I stayed at a Holiday Inn Express last night, so I wiped think I'm good.
Re: Noise
« Reply #16 on: September 29, 2012, 08:49:47 PM »
Made some progress before it hit 97 degrees and beer 30...
Re: Noise
« Reply #17 on: September 29, 2012, 08:51:30 PM »
I had the valve cover off, removed the rockers and push roads, and broke free a few of the head bolts before I quit. Everything is sorted with some card board I turned into bolt holders.
Re: Noise
« Reply #18 on: September 29, 2012, 11:02:13 PM »
i can't remember so i'll ask - did you get new pushrods? if you didn't they're like $2 a piece so might as well do it.
Re: Noise
« Reply #19 on: September 29, 2012, 11:16:07 PM »
Nope, I didn't get new ones. They all look ok, wiped them down and blew them out with air. I'll see whats local before I button it up.
Re: Noise
« Reply #20 on: September 29, 2012, 11:19:18 PM »
that is a must, you should get new ones (they're dirt cheap anyway).
Re: Noise
« Reply #21 on: September 29, 2012, 11:51:16 PM »
I forgot to mention that my nose picked a fight with an exhaust manifold flange bolt. I didn't realize it did anything other than hurt till later.
« Last Edit: September 29, 2012, 11:51:32 PM by aka-justin »
Re: Noise
« Reply #22 on: September 29, 2012, 11:52:45 PM »
At 66k miles? I'm a little heasitant. If it was 100k+ I'd be game. How much has it run you to get it done?
Most valve springs are down 1/3 of their rate by their 5th birthday running them or not. (Biggest weakness in buying a crate motor, a few of those springs have been fully compressed since the motor was built...)
By comparison, the sprint car I take care of the springs are replaced each season, that's like 12 hours of runtime... BUt at 9000 LOL
If you take the head apart yourself, and take the bare head to a shop a boil out is like 20 to 40 bucks.
Valve springs are a few bucks, set about 140.. Your stock ones can be bench tested at a machine shop for probably 20 bucks... Or if you have a high school with a auto shop I've hit the teacher up to have a student test them for me and made a "donation" to teh shop fund... ;)
Valve seal kit about 20 bucks.
If I pull a head I have a shop check it for straightness and maybe have them hone it .005 just to open the surface up for being re-seated on the engine. Not a big deal... if you don't have that done, make sure the new metal is lightly sanded to open the pores of the casting back up for the sealant on the new head gasket.
CHeers
Re: Noise
« Reply #23 on: September 30, 2012, 12:07:42 AM »
CHeers
Thanks for the info sir. Its just a daily driver and I rarely hit over 3k rpm in my travels to work - I top out around 60 mph. I work at a college that has a full autoshop and I'd like to rebuild the entire motor later in it's life, but, for now, I just want to attack these lifters. I agree with you on the spring rate and I'm sure it could use the vavles being turned, but I'm not racing and it has a lot of power right now which I'm happy with until it wears down more. I think I'd be a bit premature to go so deep into the valve train.
I did notice, after pulling all the stuff off the block, the front of my cyclinder head is leaking oil down the front. I was hoping it wasn't my rear main seal, but now I can see a trail of oil down the front of the block, to the timing cover, and along the pan. I'll watch for the oil collecting around the exterior of the pan afterward.
Re: Noise
« Reply #24 on: September 30, 2012, 01:50:25 AM »
So, I talked with my father in law, a retired mechanic, and he wanted to look over the push rods and rockers. He inspected the push rods and said to rotate them and the ends look ok - along with 20 million things to do, not do, look for, clean, blow out, .......... he said it probably would still make the noise... hahaha
« Last Edit: September 30, 2012, 01:50:58 AM by aka-justin »
Re: Noise
« Reply #25 on: September 30, 2012, 09:55:06 AM »
they break in with the lifter, it will work without replacing them but that's the recommendation. if you don't replace them you should at least keep the rockers in the same spot and the pushrod ends in the same spot (on the same cylinder and the end that went in the rocker placed the same way).
Re: Noise
« Reply #26 on: September 30, 2012, 01:21:15 PM »
I put everything in order into cardboard. Got it. Almost done. Had to come back in to get the rocker arm ft. lbs.
Re: Noise
« Reply #27 on: September 30, 2012, 11:34:01 PM »
She's alive and no more TAK TAK TAK TAK TAK TAK.... but I did manage to toast the TPS sensor when I went crazy at the car wash with degreaser. So, one last sensor and it'll be purring like a kitty. ;)
<a href="http://www.youtube.com/v/viZxBt3wY0M?version=3&amp;amp;hl=en_US" target="_blank" rel="noopener noreferrer" class="bbc_link bbc_flash_disabled new_win">http://www.youtube.com/v/viZxBt3wY0M?version=3&amp;amp;hl=en_US</a>
Pics of earlier that day once I pulled the head initally off. A lot of carbon. I got all that I could off but the top of the pistons had a lot - I even soaked them with carb cleaner. Scraped the top and head too. Would have been smart to have the head boiled - but I'm too dumb.  :whistle:
« Last Edit: September 30, 2012, 11:36:54 PM by aka-justin »
Re: Noise
« Reply #28 on: September 30, 2012, 11:48:39 PM »
Probably need to take it on a road trip and get the engine nice and hot to clean the carbon out.
Re: Noise
« Reply #29 on: October 01, 2012, 08:15:17 AM »
Good work!
