Author Topic: Proper driveline angle?  (Read 1553 times)
Wheezer
« on: January 02, 2013, 06:11:47 PM »
I have a '95 YJ with a SYE kit installed and JE Reel double cardan drive shaft. I think that the guys who set up my axle (re-positioned my spring perches) got the driveline angle wrong... There is zero angle between the shaft and the diff housing. Shouldn't there a smidgen of down angle, maybe 2 degrees or so? A friend says that with zero angle the axle will twist into the positive angle (high versus low) under load, which is bad bad bad. Any advice?
Thanks!
Wheezer
Re: Proper driveline angle?
« Reply #1 on: January 02, 2013, 07:07:09 PM »
ideally should be the way you have it set (in-line) but like you say a bit under is probably safer but i don't think it's a big issue unless you have excessive axle wrap (like an SOA with stock leafs which are very soft). My opinion, Art or Bounty are more versed with this so maybe they'll chime in with some pointers.
« Reply #2 on: January 03, 2013, 12:12:42 AM »
 You should be fine as long as you have no vibes on the highway.
You would have to have tons of axlewrap on the trail for it to be an issue.
« Reply #3 on: January 03, 2013, 08:43:43 AM »
My SUA YJ has the pinion 3 degrees up, not ideal but it seems to be fine both on and off road.  If you are SUA, it will work fine.
