Author Topic: fuel line?  (Read 1527 times)
Offline lokitim
fuel line?
« on: January 05, 2013, 07:26:26 AM »
I need to replace one of the fuel lines coming from a rubber block (not sure what this is), over the cross member, & goes into a hard line. How do I go about doing this?
Thanks
1993 YJ, 4cyl, AX15 5spd,  J20 3/4 ton axles, SOA with stock springs, disc brakes on all fours, hi-steer, flat tops,33x12.50 General Grabbers on beadlocks,Warn Front Bumper, Smittybilt w/swing away tire mount rear bumper, custom Hi-Lift Mount, Bedliner interior & body sides, Flush mount tail/backups
Re: fuel line?
« Reply #1 on: January 05, 2013, 01:39:46 PM »
you have 3 hard lines there: fuel, return and evap (which is smaller diameter). For either one of the fuel lines you disconnect the "quick connect" line coupler on the frame located right under the brake booster (you need to press the 2 white tabs in the plastic coupler, the white tabs stay with the line) take the rubber line off at the rear axle, take the line off the frame (compress the holding tabs in the plastic brackets that hold the line and pull out, careful not to brake those tabs but you can use zip-ties if that happens), install your new line in reverse steps.
nothing too complicated.
