Author Topic: Finally dived into the repair work I needed (well, I started, anyway!)  (Read 5901 times)
Re: Finally dived into the repair work I needed (well, I started, anyway!)
« Reply #15 on: March 10, 2013, 10:05:22 PM »
Where's the plug location and what colors are they?  One purple?  Could be for the cigarette lighter for the stock location.  The stock location won't reach the A/C location.
« Reply #16 on: March 10, 2013, 10:06:47 PM »
Black and red: they come from the same bunch of cables as those that connect to the heater/ventilation system.
« Reply #17 on: March 10, 2013, 10:53:18 PM »
Well, the stock ash tray mounts right below the Heater Vent controls.  I'd just tie them up if you're not going to use them.
« Reply #18 on: March 11, 2013, 12:01:59 AM »
i'm not positive on the flow rate, you'll have to test and see if you can, you can compare one of them with a stocker, same rail running into some bottles (injectors opened and measure the fuel quantity) or just install them and see how it goes. I ran 43 psi and didn't have any problems starting it (actually i even had it all the way close to 50 but was blowing black smoke but was starting just fine) so i don't think that's your problem.
« Reply #19 on: March 11, 2013, 07:22:28 AM »
I'm sure I can find a use for them...  It's just good to know what they are.
I think I will just install them and see how it goes...
