Author Topic: Calif folks If you saw this jeep  (Read 6657 times)
Re: Calif folks If you saw this jeep
« Reply #15 on: June 30, 2013, 01:41:11 PM »
His is a newer jeep I believe it has the 4 speed automatic.
Well, if he wants to get it back on the road fast and cheap he should stick with what it has.  Otherwise, swap away.  A 32RH/TF999 would be pretty bullitproof but he's lose OD.  AW4 is an option as well.  If he wants to do adapters then a TH700R4 or a 4L60E would be a good choice.  They're super common unlike the AW4 but adapters aren't cheap.
« Reply #16 on: July 21, 2013, 03:57:20 PM »
He says she is naked right now so this is the only photo he will send.  Fixing not only the trans but getting a 3" lift too.
« Reply #17 on: July 21, 2013, 04:52:36 PM »
What he3 says he is doing to it.
Quote
Drive line new trans, bigger trans cooler, then hopefully new exhaust winch 3 more inches of lift and 35's. I'm gonna go through rear ends and transfer case while I've got it stripped down also.
