Author Topic: steering box  (Read 6151 times)
Offline SamsonJR
  • Samson Jr and Willydog in VT
Re: steering box
« Reply #15 on: July 31, 2013, 10:21:56 AM »
I'm already on top of that, thanks though. I'm going to borrow my Dad's puller. I know better then to no remove my pitman arm! lol
Re: steering box
« Reply #16 on: July 31, 2013, 12:00:36 PM »
I run a '99 Durango box on my YJ, I believe there is no snow-plow option in '99 but there is for the '98.
There's a trick  to removing the pitman arm easily.  Tighten the puller and, using a 3 lb sledge, hit the side of the arm where it attaches to the steering box at a 90* angle to the steering shaft.  Tighten, hit, repeat.  The hammer blow temporarily egg-shapes the pitman arm hole and helps it pop right off.  Same method works great for ball joints and TRE's.
Re: steering box
« Reply #17 on: July 31, 2013, 12:31:24 PM »
Definitely remove the pitman arm off while the box is still on the Jeep.
Offline mrcabinet
Re: steering box
« Reply #18 on: August 01, 2013, 06:16:02 PM »
Yup, puller and a BFH is the way to go. If you're doing it by yourself, a floor jack with a block or two really helps to get the box up to the frame and steady it.
Re: steering box
« Reply #19 on: August 02, 2013, 09:03:51 AM »
I second this strategy; before I was pointed in this direction, I was not able to get the pitman off my Jeep...
Offline SamsonJR
Re: steering box
« Reply #20 on: August 26, 2013, 03:30:36 PM »
hey guys, update on my '91's steering, I decided to use the parts I bought about a month ago "new steering shaft, bearing, retainer and cap" and see how it drove. I figured worst comes to worst I just unbolt the shaft from the steering box and replace the box. Well It's driving a lot better. the joints were SHOT in the old shaft. I still have a little bit of play "about a 1/4 inch" but it's a lot tighter then it was. This is good because needing to put so much into the '93, I can use the steering box fund towards that for now :) and upgrade later on
Re: steering box
« Reply #21 on: August 26, 2013, 04:27:50 PM »
It's, "worse come to worst".    :trollface:  :lol:  Congrats on getting is fixed though.
Offline SamsonJR
Re: steering box
« Reply #22 on: August 26, 2013, 04:50:24 PM »
lmao, yeah.. I'm not a English major..clearly  ;)
