Author Topic: '93 yj vibration at 40 mph  (Read 6896 times)
Re: '93 yj vibration at 40 mph
« Reply #15 on: August 24, 2013, 11:38:16 PM »
Oh yea,, totally agree, I was just trying to make them tie together.. LOL
If you can make sure one is to spec then check the other you can tell if the axle tubes and knuckles are in their original position or if the axle is modded..
I've had 1 side twist before.. weld broke.
Thought of another possibility.. My YJ used to have a low frequency vibe in the front that went away when I converted to Hubs and got a 1 piece axle on the right side and got rid of the disconnect. Any time I have the hubs in there is a "rumble" under the front..
« Reply #16 on: August 25, 2013, 12:06:04 AM »
OK, but...
Quote
I had the front driveshaft done not to long ago and it was balanced, the yoke has some play but nothing crazy. I removed it and drove and still doing it.
« Last Edit: August 25, 2013, 12:06:16 AM by Jeffy »
