Author Topic: Hard Top rear window hinges bent; Can they be replaced?  (Read 5617 times)
« on: September 09, 2013, 01:12:32 PM »
I just noticed that the hinges for the rear window of my hardtop are bent.  This is why they were letting water in.  I used weatehrstripping to seal it for now (at this time, water is only coming in on the pass side window), but the glass is still sticking out.  Any idea where to get those hinges to fix the problem properly?
Re: Hard Top rear window hinges bent; Can they be replaced?
« Reply #1 on: September 09, 2013, 10:25:54 PM »
I'd check omix-Ada and crown.  Other then that you're SOL I think.  Maybe you can bend them back?
« Reply #2 on: September 09, 2013, 11:08:12 PM »
Maybe they can be straightened and then have plates welded to them.
« Reply #3 on: September 10, 2013, 08:10:34 AM »
I have not taken them apart, but they seem to be plastic, not metal...  It could be just a covering, though.
« Reply #4 on: September 10, 2013, 07:27:22 PM »
IIRC there's a plastic cover over the bolts.  The hinges is metal.
« Reply #7 on: September 12, 2013, 11:46:00 AM »
Thanks, I just ordered it...
I looked at mine and they're all metal.  The cover does sorta look and feel like plastic but I think it's how it's made.
