Author Topic: Bastard Pack?  (Read 9563 times)
Re: Bastard Pack?
« Reply #15 on: November 26, 2013, 10:54:10 PM »
You need four leaf packs since your taking the main leaf and in his case the second leaf out of each pack.
I think you misunderstood, you only need a donor front pair of springs and you're only adding one additional leaf to each of your existing 4 spring packs.  You used the two longest leaves in each front spring pack for your additional four add-a-leaves.  Adding one leaf per spring pack gives approx. 1.5" of lift without making the ride harsh.
The reason for only using two front spring packs is it offers the same amount of lift when added to all 4 corners, and the front packs have slightly more arch than the rears.
It's worth the trouble if your stock springs aren't bent or negative arched.
I went a step further when cutting the spring eyes off the top leaves by leaving about 1/8 of the spring eye.  This slight upward curve supports the spring eye in the bastard pack and strengthens the spring where it needs it most, between the spring eye and the second leaf.   This is where stock springs commonly bend.
Offline bigal389
Re: Bastard Pack?
« Reply #16 on: November 27, 2013, 11:01:17 AM »
I'm going to try to get everything together this weekend to do this. I'll post the results when it complete.
Al
87 Jeep Yj 2.5 all stock for now
Re: Bastard Pack?
« Reply #17 on: November 28, 2013, 01:18:48 AM »
There are several versions/combinations of leaf springs used in YJ's.. Depending on engine, hard top vs soft top.
My 95 4 cyl with hard-top had 4 leaf front packs and 5 leaf rear,
When I ordered my springs I ordered 4 rear packs, because I had added a winch and bumper..
Rode fairly level. I'm now looking at new springs after 75K or so cause the front ones sagged (Second set.. first set made about 75K as well )
Offline bigal389
Re: Bastard Pack?
« Reply #18 on: November 30, 2013, 08:42:59 PM »
I got the springs of the bastard pack yesterday.  I ended up getting them out of a mid 90's s10 blazer, no Yj springs were available. Paid $45 for everything. I'll post pictures and results when I get to bud them.
Al
Offline bigal389
Re: Bastard Pack?
« Reply #19 on: December 13, 2013, 04:12:02 PM »
 I'm going to try to get the Bastard pack done this weekend. I have to do the wife's brakes in the morning, then I'll get started. I'll post before and after pictures and ride results when I'm finish.
Al
Offline bigal389
Re: Bastard Pack?
« Reply #20 on: December 14, 2013, 08:08:49 PM »
Ok I didn't get any pictures before I got started due to the weather and a crowded shop. I finished the front but I ran into a few problems. All of the spring hanger bolts froze up as were the u bolts. I got the hanger bolts freed up and out but had to use the torch on the u bolts. I finally found replacement u bolts after about 2 hours of looking. The re assembly went without a hitch. I used the Main spring from the s10 springs with the eyes cut off, this lifted the front a total of 2 1/2 inches which set the Jeep about a 1/2 inch high in the front but the ride is sooo much better. I am going to try to get the rear done tomorrow and will post picture after.
Al
Re: Bastard Pack?
« Reply #21 on: December 15, 2013, 12:33:27 AM »
Cool, keep us posted :dance:
Re: Bastard Pack?
« Reply #22 on: December 15, 2013, 12:45:05 PM »
So you added the S10 leaf to the original factory spring pack? Or a aftermarket?
Thanks
Offline bigal389
Re: Bastard Pack?
« Reply #23 on: December 15, 2013, 07:40:53 PM »
I added an S10 leafs to the stock Yj springs. I added the main leaf from the s10 to the front. I used large chop saw and cut the eyes off the s10 spring. The line up pin on the s10 spring is offset so more will be cut off one side than the other, I cut the eyes off at 21 1/2 " from the center hole, this left about an inch from the eyes on the yj springs. I used grade 8 bolts and ground the heads round to make new line up bolts, they will need to be 2" long and a washer installed to keep them from pulling through the s10 spring since the hole is bigger. I needed longer u bolts for the front, believe it or not O Riley's had them. Be sure to tighten them evenly and add grease to all the spring hanger bolts.  The best way I found to open an close the clamps was by heating them with a torch. For the rear I used the second s10 spring an only cut 2" off the end with the clamp. I finished the rear today and it rides a drives like a different jeep. I have taken the track bars off yet bit I was told it improve it even more. I gained an 1 1/2 in the rear. I like the stance.
Al
Re: Bastard Pack?
« Reply #24 on: December 15, 2013, 09:18:45 PM »
Looks good
I'm totally lost on this one (I don't get it):
isn't the S10 spring leaf sandwiched between the stock leafs? and where would you use  the washer (if it's on top it wont let the perches seat properly). Maybe you can explain - been trying to visualize it but didn't come up with anything.
Re: Bastard Pack?
« Reply #25 on: December 16, 2013, 05:57:32 AM »
Looks great.  Consider installing TJ fender flares for even more tire clearance.
I ran bastard packs and TJ flares with 31" tires for years on my YJ, before upgrading to SOA.
Offline bigal389
Re: Bastard Pack?
« Reply #26 on: December 16, 2013, 07:06:05 AM »
The S10 spring installs on top of the existing springs similar to an add a leaf. The hole in the S10 spring is bigger, I used 3 washers on each spring that fit inside the hole basically as a shim and to keep it high enough to use as a line up pin.
Al
« Last Edit: December 16, 2013, 08:07:23 AM by bigal389 »
Re: Bastard Pack?
« Reply #27 on: December 16, 2013, 09:39:09 AM »
Al
I thought add-a-leaf goes in between - so right now if i understand this correctly the extra leaf pulls on the clamps go give you the extra lift?
Offline bigal389
Re: Bastard Pack?
« Reply #28 on: December 16, 2013, 12:17:55 PM »
Yes that's the way I have them. I guess I had a brain fart when I installed them. I'll pull them back out and change them around. Thanks for pointing it out to me.
Al
« Last Edit: December 16, 2013, 12:39:16 PM by bigal389 »
Re: Bastard Pack?
« Reply #29 on: December 16, 2013, 12:39:25 PM »
I would have left the clamps open.  If you're careful you can get them to stand straight like a U,  This will keep the pack from fanning out but still allow thw pack to have full movement.  If you're afraid of pulling a leaf far enough to come out you could always drill two holes though the clamp and put a bolt though it.  Or if you want to clamp them make sure there is a leafs width worth of gap before you bend the tabs over.  You don't want the clamp to be pinning all the leafs together.  I'd also consider tapering the ends of the leafs if you haven't done it already.  This will help allow them to flex a little better.  Also make sure you paint the leafs while they're apart.  You don't want them rusting together.  Oh and instead of rounding out a hex head bolt you'll want to use an Allen head.
