Author Topic: Bigger Battery?  (Read 8038 times)
Offline BoringDave
Re: Bigger Battery?
« Reply #15 on: December 05, 2014, 03:21:32 PM »
BTW: two batteries is 106 lbs vs 75 lbs.
Maybe that's why mine is so gutless?
Iirc when I got my 95 it had a groupe 31 in it. I remember it was big!
Re: Bigger Battery?
« Reply #16 on: December 05, 2014, 06:30:56 PM »
You'd know if you had a group 31 in there.  It won't fit on a stock tray.  It's the battery spec'ed for big rigs and tractors.
Offline Wrench
Re: Bigger Battery?
« Reply #17 on: December 21, 2014, 02:22:13 PM »
When I need to get a new battery it will definitely be a Sears Platinum/Odyssey though.  They're easier to get a hold of and their Deep Cycle.
When you get down to the "brass tacks" of lead-acid batteries, the ampacity is directly related to the lead and acid content, which is where the weight is.  I have seen "group 24" batteries differ in weight by a large amount, and their true amp-hour capacities are equally different.  Your 75 lbs of lead-acid battery will never be the same amp-hour rating as 106 lbs of lead-acid battery.
Deep cycle batteries are designed for slow but deep discharge and recharge.  Standard car batteries are designed for quick bursts of power, but dont like deep discharges.  Using deep cycles for a vehicle or using a car battery for deep cycles can shorten their lives.  But...if you use a pair of deep cycles in parallel, the short bursts of power are split between the two batteries and will retain their standard lifespan.
Whatever you do, dont by batteries from Walmart, unless you are willing to rely heavily on their warranty.  I own an RV Service business and I see more dead Walmart batteries than all other brands combined.
Paul
1984 Chrkee
Re: Bigger Battery?
« Reply #18 on: December 21, 2014, 07:59:51 PM »
The two batteries in question are both deep-cycle/starter batteries and both are AGM's.  The question being is dual battery overkill though compared to just upgrading to a larger battery.  Ignoring the added feature of being able to weld with them.
Offline 95 Lowbuck
Re: Bigger Battery?
« Reply #19 on: December 23, 2014, 07:53:19 PM »
Yellow Tops are deep cycle, and again 7 years is not too bad for a battery.
« Last Edit: December 24, 2014, 12:13:32 PM by Jeffy »
