Author Topic: What tools to take...  (Read 5930 times)
« on: April 06, 2006, 10:15:23 PM »
Well, I want to start making a list.  Here's a start.  I'm sure I'm missing something.
Basic:
Combination Wrench Set
Needle Noise Plyers
Channel Lock Plyers
Slip-joint plyers
Dikes/Diagonal Plyers
Duckbill Plyers
Assorted Screwdrivers (Philips & Standard)
Small, Medium & Large Adjustable Wrench
3lbs Sledge Hammer
Combination Wrenches (SAE & Metric)
Vice-Grips
Farm/Hi-Lift Jack
Supplimentary:
Ratchets (1/4", 3/8" & 1/2")
Assorted Sockets
Universal Sockets
Assorted Ratchet Extensions
Adapter Sockets (1/4-3/8, 3/8-1/2, etc...)
Large Punch
Line-Up Tool
Pry Bar
Feeler Gauge
Torque Set
Hydraulic Bottle Jack
Tire Plug Kit
Good to also have:
Gear Puller
Pitman Arm Puller
Reverse/E-Torx Set
Torque Wrench
Nut & Stud Remover Set
Damaged Screw Remover Set
Hex Key Set
Tap & Die Set
Grease Gun
Vacuum Gun
Suction Gun
Lock Ring Plyers
Tyre-Plyers
Cool to also have:
Winch
OBA (Enginge or CO2)
Air Tools
Craftsman 4-in-1 Double-Sided Box End Wrench SAE & Metric(*These are slick!)
Emergency:
First Aid Kit
Basic First Aid and CPR Training
Fire Extinguisher
trailerrails
« Reply #1 on: April 07, 2006, 08:57:37 AM »
I try to do all my work on my jeep with the tools I carry with me. If I have to run to my main tool box for a tool then it gets put in my jeep tool box. I went over my jeep and figured out pretty much every socket or open end wrench I should ever need for a trail repair. I put a few extras in there of real common sizes too. Co2 or OBA is a must. As well as some starting fluid if you are not running beadlocks like me. I might as well start a list of stuff you forgot.
Bailing wire
Starting fluid (for reseting beads)
Misc tape (duck, electial)
Extra fluids
   Gear oil
   ATF (very important if you have an auto tranny)
   Motor oil
   Brake fluid
Spare U-joints
CB
Ohm meter
Lots of spare fuses (don't forget the ones under the hood)
A gallon of water (for drinking or for the rad)
High lift (can be used as a winch or removal of stubborn teeth)
     I know you put this one down but I can't belive how many people
     wheel without one.
Erik
« Reply #2 on: April 07, 2006, 11:26:50 AM »
advance auto's magnet on a telescoping stick thingy....
handy for pulling broken pieces of axle shaft out of the axle tube on the side of the trail... handy for getting dropped bolts out of ______..... handy for playing with.  $5 and fits anywhere
SMC4WD
« Reply #3 on: April 07, 2006, 04:13:06 PM »
I once read somewhere that:
"Any tool you ever need in you garage is the same tools you need to take 4wheeling with you"
Now this could end up being a really popular topic.   Are we going to point out what tools to have, or what tools to take with you wheeling?
Erik
« Reply #4 on: April 07, 2006, 04:19:57 PM »
for $200ish sears has a nice black plastic tool box with 4 red plastic pull out drawers that is fully stocked.  every "normal" tool you would ever need in your garage or the trail... and it fits nicely behind the back seat  :D
  • Poseur ExtraordinaireŽ
c'mon lazy....give the link
« Reply #5 on: April 07, 2006, 07:28:10 PM »
Quote from: "Erik"
http://www.sears.com/sr/javasr/product.do?BV_UseBVCookie=Yes&vertical=TOOL&pid=00933263000&subcat=Mechanics+Tool+Sets
Yellowcritter
« Reply #6 on: April 07, 2006, 07:47:27 PM »
I also carry a large C-clamp for u-joints and such, a rubber mallet for hooking the disco's back up, and a magnetic pad to hold whatever you need while under your toy.
Here's what the pad looks like.
http://www.sears.com/sr/javasr/product.do?BV_UseBVCookie=Yes&vertical=TOOL&pid=00947086000&subcat=Automotive+Specialty+Tools
Erik
« Reply #7 on: April 08, 2006, 03:56:36 AM »
yes mozman, that's exactly what i was referring to.....  great buy for anyone looking for a toolkit....
littleredbeater
« Reply #8 on: April 08, 2006, 05:03:13 AM »
a phone and my AAA card. they say they'll get to you anywhere. haha
pk11
« Reply #9 on: April 08, 2006, 09:52:29 AM »
At the rate this list is growing,
will need one or two small trailers ?
Chowmaster
« Reply #10 on: April 08, 2006, 05:52:54 PM »
i bought a handy little 1/4 and 3/8 socket set from home depot for $39. i also carry a pair of vise grips, a small walmart bottle jack, a 4-way, jumper cables, and hammer.  i drove my jeep about 17,000 miles over the last year and havent had any problems cept for a battery.
if i go wheeling or on a trip i carry some more crap, mostly basic tools.
dont forget your supplies:
duct tape(duh)
zip ties
hose clamps
heater hose
jumper wire
fuses
serpentine belt(keep your old one for a spare when you get a new one)
small wood block(4x4x8)
fluids
« Reply #11 on: April 08, 2006, 06:03:03 PM »
Well, I was going to keep stuff like fluid in a different area as well as spare parts.
« Reply #12 on: April 16, 2006, 09:32:31 PM »
Bump, anyone else think of anything?
« Reply #13 on: April 26, 2006, 05:37:17 PM »
ya you also want ducktape and bail wire.. or mechanics wire as we callet.... we have been saved by mechanics wire to help us limp our jeep back to camp with mechanics wiore when tirodends brake and other varoius things...
SMC4WD
« Reply #14 on: April 26, 2006, 09:34:55 PM »
Choker chain (or any good chain)
Tire plug kit
Gasket sealer
spare nuts, bolts and hardware (castle nuts and cotter pins)
blanket, warm clothes sealed in ziplok baggies.  Socks and shirts or anything else in case you find out thst the water puddle you just drove in was deeper than you thought.
hidden food...   granola bars or power bars, for just in case you'll be spending the night
(nothing yummier than manifold burrito's)
Another person, rig, vehicle of some sorts!  Never ever go wheeling alone, and make sure someone knows where you are going and an estimated time you'll be back.
