Author Topic: TJ fuel pressure??  (Read 2986 times)
Offline Hunter02
TJ fuel pressure??
« on: July 12, 2016, 12:29:18 AM »
Gentlemen, is there a fitting where I can tap in to measure fuel pressure coming from the fuel pump? If can, can you give the location and maybe a picture? Neither of my manuals show one but I figure there must be a way.
Thanks,  Hunter
'98 TJ
2.5L Auto
Re: TJ fuel pressure??
« Reply #1 on: July 12, 2016, 12:57:51 PM »
There's a special took for that.  Basically you're going to run an inline adapter to the fuel line.
I think you should be able to use a universal fuel pressure gauge kit too.
Offline VA_YJ
  • Now I need a CJ...
« Reply #2 on: July 15, 2016, 11:33:21 AM »
There should be a Schrader fitting (looks like a bicycle tire valve) on your fuel rail (pipe on top of motor).  You hook the pressure gauge to the fitting.  It will spit some fuel when you connect, so be careful not to start a fire.
« Reply #3 on: July 15, 2016, 06:15:44 PM »
They got rid of that on the TJ.
Offline Hunter02
« Reply #4 on: July 15, 2016, 09:37:21 PM »
That's a shame. That's what I had been hoping for.
Hunter
Offline VA_YJ
« Reply #5 on: July 18, 2016, 12:50:41 PM »
Hunter, sorry for the bad info.  My 1998 TJ (4.0 liter) has the Schrader valve like my 1995 YJ (2.5 liter).
