Author Topic: Stock camshaft specs  (Read 9646 times)
Offline losduos
  • Newbie
« on: March 18, 2017, 01:23:10 PM »
Hi, I'm new here and in the process of rebuilding my 2.5. Does somebody know the original cam specs? Considering getting one ground...
Thanks!
Re: Stock camshaft specs
« Reply #1 on: March 19, 2017, 05:10:59 PM »
What year is your Jeep?  YJ's and TJ's have different cam profiles.
Offline losduos
  • Newbie
« Reply #2 on: March 20, 2017, 10:04:45 AM »
Right, it's 95 YJ...
« Reply #3 on: March 20, 2017, 02:26:59 PM »
Valve Lift - 0.424"
Valve Overlap - 46*
Intake Duration - 270*
Exhaust Duration - 270*
Offline losduos
  • Newbie
« Reply #4 on: March 21, 2017, 01:24:24 PM »
Thanks, do you know the standardized values by any chance?
Comp is offering the following and I'd like to compare to stock:
200/206 @.050" .416"/.435" on 113 (to work with stock injection and springs)
« Reply #5 on: March 21, 2017, 06:55:18 PM »
I don't believe Comp Cams makes anything for the Jeep 2.5L.
Offline losduos
  • Newbie
« Reply #6 on: March 22, 2017, 04:31:03 PM »
Yeah, but they can grind you one. And that's what they came up with.
Offline JC93YJ
« Reply #7 on: March 23, 2017, 07:18:33 AM »
http://schneidercams.com/AMC_I4-hyd.aspx
Schneider also has some cam options. Pretty good prices as well. Just another option. They can also custom grind you one.
Joe
93 Jeep YJ- 50 Shades of Black.
Stock 2.5....for now
« Reply #8 on: March 23, 2017, 03:37:36 PM »
Hesco makes one as well.
http://www.hesco.us/products/7724/new-products/167924/rvob4-25l-camshaft
There's also the Mopar Performance Purple Cams which are defunct but you can someone to duplicate them.  Straight from the FAQ - http://4bangerjp.com/forums/index.php/topic,4.0.html
Camshafts:
                      P4529656
Factory Engineered Hydraulic Cam and Tappet Package for Mild Competition Application 240-240-24* Duration, .430" Valve Lift, 108 Centerline
                      P4529657
Factory Engineered Hydraulic Cam and Tappet Package for Mild Competition Application 248-248-32* Duration, .440" Valve Lift, 108* Centerline
                      P4529658
Factory Engineered Hydraulic Cam and Tappet Package for Mild Competition Application 256-256-40* Duration, .450" Valve Lift, 108* Centerline
                      P4529659
Factory Engineered Hydraulic Cam and Tappet Package for Mild Competition Application 260-260-44* Duration, .460" Valve Lift, 108* Centerline
                      P4529660
Factory Engineered Hydraulic Cam and Tappet Package for Mild Competition Application 268-268-52* Duration, .480* Valve Lift, 108* Centerline
« Last Edit: March 23, 2017, 03:38:10 PM by Jeffy »
Offline losduos
  • Newbie
« Reply #9 on: April 03, 2017, 01:43:27 PM »
Thanks guys.
There is also 505 Performance offering 3 stages. Stage 1 is very close to stock I think, probably the most reliable one. Stage 2 looks also interesting but quite a bit more aggressive. Any advice?
http://www.shop.505performance.com/product.sc?productId=381&categoryId=40
http://www.shop.505performance.com/product.sc?productId=382&categoryId=40
« Reply #10 on: April 15, 2017, 12:32:49 PM »
The one Hesco used to sell was made by Clay Smith. they had 4 different grinds as I recall, I have the "RVOB" version Hesco sold.
