Author Topic: AutoMeter Gauges  (Read 9981 times)
0 Members and 4 Guests are viewing this topic.
Offline bootguy
AutoMeter Gauges
« on: November 15, 2018, 09:18:23 PM »
1994 YJ 2.5L FI with 38RH automatic transmission.
I am looking at purchasing a complete set of replacement gauges from Autometer ( https://www.autometer.com/jeep-kit-yj-complete-instrument-kit.html ).  My question is I know there is some signals that have to go to the engine management system, will replacing the sending units and running directly to the gauges give me additional errors/issues?
Re: AutoMeter Gauges
« Reply #1 on: November 16, 2018, 01:17:40 PM »
Just get the gauges that use the same signal.  My guess is that they use the correct gauges to use those signals.  The fuel sender, oil pressure and alternator signal come to mind.  Speedometer reads off the pulse signal off the PCM as well as the tach.
« Reply #2 on: December 07, 2018, 01:59:36 AM »
Please come back and update on this ,, I've been eyeballing the same kit,, after so many years my gages are starting to get a bit wonky.. Its only been 25 years where has quality gone! LOL <joke>
« Reply #3 on: December 09, 2018, 06:47:07 PM »
Hey, you get used to how off the gauges are.  It's more along the lines if, is the gauge moving at all, if it is and it's not pegged, then you're okay.
