Author Topic: oil pressure  (Read 5997 times)
oil pressure
« Reply #15 on: April 27, 2006, 03:53:19 PM »
The reason for not using teflon tape is because not everyone knows how to use it properly.  If you have too much hanging off, it could get into the oil lines and cause problems.  You shouldn't need to add any if you have it on tight though.
pedrolobo1978
oil pressure
« Reply #16 on: July 06, 2006, 02:15:46 PM »
I seem to be having the same negative oil pressure problem someone else posted.  I haven't tried a new sensor yet but have a few questions about sensors.  First is kind of a no brainer, should oil be leaking into where the wire connects to the sending unit? I assume this sensor is broken and is what is causing my negative oil pressure readings.  The second question I have is about another sensor I know is broken but do not know what it is called.  I have a 2.5 liter in a 1992 wrangler and there is a sensor on the rear driver side of the head which attaches next to the valve cover.  Thanks for any feedback.
Pedro
