Author Topic: Calculating proper injector size  (Read 1725 times)
Beachbum
« on: June 06, 2006, 09:43:42 AM »
I've been researching upgrades for the fuel and injector system on the 2.5. While doing so I ran acroos this link and thought I would share it.
http://www.injector.com/fuelinjectors.php
I also found this link to a place that advertises injectors for increased performance in the 2.5. Has anybody installed performance injectors in your Jeep ?
www.fiveomotorsport.com/injector_SetsJEEP.asp
What about adjustable fuel press. regulators? Any experiences, advice or stories to share?
Jhcujo
« Reply #1 on: June 07, 2006, 05:56:08 PM »
Question that I have is are the stock injectors 19 PSI? I have been looking at a place that will clean,replace all parts and flow test them to 1%. They can do this for half the price. So unless stock is less then 19. I think you might just want to get them cleaned and flow matched.
http://www.witchhunter.com/index.htm  this the place that I was looking at
Beachbum
« Reply #2 on: June 07, 2006, 07:45:15 PM »
I'm doing some performance upgrades to my jeep, that should make it breathe much better. I'm wondering if the stock injectors will feed enough fuel after the upgrades. The first link in this thread gives some formulas to play with by plugging is some numbers. I'm hoping after my upgrades my motor will be putting out around 160 HP (more would be nice) stock motor is rated @ 125 HP. By using the formulas in the 1st link the factory injectors won't be enough, I'm just wondering if anybody has made similar upgrades to what I'm making and if so were different injectors needed.
