Author Topic: gear box oil filling  (Read 2398 times)
yjdave
« on: June 14, 2006, 06:20:41 AM »
what measure is the torx bolt that i need to unscrew to fill up the gear box oil? is it a t60?
« Reply #1 on: June 14, 2006, 06:42:14 AM »
Gear box? Which gear box?
You're manual trans?
« Reply #2 on: June 14, 2006, 11:49:07 AM »
If you have a manual and are looking at the torx that I think you're looking at, don't.  It should read DO NOT REMOVE, if I remember right.  Behind it is a spring of some sort I believe.  The filler bolt should be a standard hex bolt.  It's on the forward part of the case, just behind the bellhousing.
yjdave
« Reply #3 on: June 14, 2006, 02:25:20 PM »
i have an ax-5.
yes i heard the story about the dont remove torx, thanx for confirming it.
