Author Topic: Spring over axle?  (Read 2254 times)
Offline 95jeeper
Spring over axle?
« on: July 06, 2006, 08:52:12 PM »
I have been thinking of doing a spring over axle lift?  That should give another 3" or 4" of lift to my already 5" lift.
Anyone done one or know anything about it?
I saw a kit on quadratec but is pricey and i don't need have the stuff it comes with.
http://www.quadratec.com/products/16300_305.htm
The price in the catalog is something like $304
Does anyone recommend the idea or what?
Any help would be greatful?
95 rio grande 4" Skyjacker lift 1" shackel 33" tires, efan, 4.0TB, kn air filter, exhaust, and sound system. NV3550 conversion
Re: Spring over axle?
« Reply #1 on: July 06, 2006, 09:34:58 PM »
Quote from: "95jeeper"
You do realize a SOA will give you a minimum of 5.5" of lift right?  If you have 4" leafs you'd be just shy of 9".  SOA on 4" leafs isn't a good idea.  Not to mention you get crappy driveshaft angles.
shotgun
Spring over axle?
« Reply #2 on: July 07, 2006, 08:09:14 AM »
I agree with Jeffy, stacking big lifts is not a good idea.
However, I come from an area where the bigger the better and it is not uncommon for a jeep to run 38's and bigger.  This is not just the mere stacking of lifts.  The axles will need to be at least 3/4 ton and most go 1 ton. You'll need to  cut and turn the front axle, careful not to **** this up.  The four banger is definitely out of the question, which makes more driveline issues.  Most would go with a SBC 350 /t350/ np205 or atlas for the shortest driveline. If your an AMC engine fan it changes to 304/360/401 motor and most likely a t-18 with a Dana 300.  By your name I can hazard that your leaf sprung. That makes this a bit easier.  If your in a TJ gettting the  kind of lift your talking about takes custom brakets and trusses.
Yeah, you may not need half of what is in the kit, but if your stacking on top of your existing lift, you'll probablly need 10 times more.
