Author Topic: AtoZ vs. Big Daddy roceker gaurds  (Read 2857 times)
01amberfirewv
« on: July 18, 2006, 06:24:17 PM »
The rocker gaurds I have now do not bolt to the bottom of the Jeep and only cover about 1" under the Jeep. I am going to replace them with something better and I have been considering AtoZ because I have heard good thing about them, they have a fair price and they offer full coverage under the Jeep. The Bd soild aluminum rocker gaurds are not much more and are lighter which is good ocnsidering I have a 4banger. I need gaurds that come up at least 5" and I can't tell if the Bd ones do. Any suggestions?
« Reply #1 on: July 18, 2006, 08:39:43 PM »
You might want to consider just making your own with some angle iron.  Something like 6x6x1/4".  I know a lot of guy's who have done their own.
Problem with Aluminum is that it gouges fairly easy when up against a rock.  Steel plate would just scratch the paint off.
SMC4WD
« Reply #2 on: July 18, 2006, 09:47:18 PM »
A suggustion would be http://www.offyourrockers.com/ by Dan Duffy.
He does grat work, and could custom too if you ask him. I'm running his rockers and custom short corners.
« Reply #3 on: July 18, 2006, 10:01:41 PM »
You might want to look into the rocker pannels by www.fourxdoctor.com.  These are priced right at around $265, have good reviews, and the tubing keeps rocks that you slide into from doing less damage.  Another option that covers more of the underside of the Jeep is from www.shrockworks.com.  This is one costs a little more but you have a little more options than the previous.  Depending on how much lift you have the bar is a great step for getting in without the lost clearance of nerf bars (looks alot better also).
« Reply #4 on: July 18, 2006, 10:19:47 PM »
Quote from: "SMC4WD"
His rockers only go under the body maybe 1/4" though.  He's going to replace his existing rockers for some with more coverage.
BTW: I've seen OYR's buckle twice.  It wasn't pretty.
