Author Topic: tire rub revisited  (Read 2182 times)
frosty
tire rub revisited
« on: August 03, 2006, 05:40:25 AM »
So I put the washers on my bump wheel stops and they worked but the fact is with 235 r15 tires there should be no rub.  I cant get it out of my head that there is something wrong with my jeep.  Is it a waste of my time to bring the truck to a body shop to get checked out or has anyone else experinced tire rub on a tj with this size tire
Billy
Re: tire rub revisited
« Reply #1 on: August 03, 2006, 07:53:55 AM »
Quote from: "frosty"
Billy
You'll need to be more specific on the rubbing location. If you can take pics of the rub area, we'll be better to help you diagnose the problem.
Adding spacers to the bump wheel stops doesn't really tell. You could mean the steering stops, the suspension bump stop, etc. The steering stops will effect rubbing even with 235's, but I'm mistified if the bump stops are a problem with rubbing with 235's.
frosty
tire rub revisited
« Reply #2 on: August 03, 2006, 08:37:44 AM »
it rubs on the lower passenger control arm
tire rub revisited
« Reply #3 on: August 03, 2006, 03:00:18 PM »
If it rubs while turning hard right, the back of the tire turns toward the control arm on the passenger side. For it to rub, your steering stops shouldn't be there, the track bar is probably worn, and potentially the control arms bushings also.
The steering stop bolt is metric fine so you may need to replace it. When replacing it, you'll need a nut to help lock it down and secure it. You could add washers between the nut and the head of the bolt to help the bolt retain its straightness. To add, the track bar needs to be replaced. It centers the axle under the vehicle statically and when the front wheels are facing directly forward. Turn you tires straight. Take a measure off the frame on both sides to see if the axle is centered. Then turn the steering wheel right/left and see if the frame and axle mounts are rigid. If there is play in the track bar mount in these areas, it needs replacement. Lastly, the suspension has 4 control arms. Each one is attached to the frame and the axle through rubber bushings. These bushings in time will wear and the front axle will have play and movement. Check to make sure these bushings are fine. Moving the steering right/left is also show movement in the axle mounts.
Hope this helps.
