Author Topic: Good coil replacement  (Read 2708 times)
Offline dexetr30
  • 4BangerJP.com® Donator
  • Aloha Mr. Hand!
« on: August 14, 2006, 06:42:35 PM »
Does anyone have any recommendations on a good aftermarket ignition coil (You have used or are now using) to replace my stocker with? I’m not sure if I’m definitely going to replace the coil or not but, if someone can give me some good info on a product I just may switch it out. Also, tell me your experience after you installed it.
Thanks guys…
GreenBayjeeper
« Reply #1 on: August 14, 2006, 07:49:33 PM »
http://www.4bangerjp.com/forums/viewtopic.php?t=1540
And as an update to that post, I'm getting better gas milage than I've ever gotten.  20.5 mpg mostly in the city!
Offline dexetr30
  • Aloha Mr. Hand!
« Reply #2 on: August 15, 2006, 08:14:07 AM »
Thanks GreenBayjeeper.
Offline dexetr30
  • Aloha Mr. Hand!
« Reply #3 on: August 15, 2006, 08:36:33 AM »
What about this set for my 02? I think this may be the same as or simular to the one your referring to GreenBayjeeper.
http://www.4wd.com/newsite/shop/productdetail.asp?pid=31732K&model=tj&cat=7&kid=359&catid=359&mid=n
GreenBayjeeper
« Reply #4 on: August 16, 2006, 09:13:27 PM »
That looks exactly like the setup for my '98.  Same color even.
Color notwithstanding, I couldn't be happier with the set up, and recomend it to anyone who's in the market.
Offline dexetr30
  • Aloha Mr. Hand!
« Reply #5 on: August 17, 2006, 06:40:17 AM »
Excellent, looks like I'll be ordering it this weekend.
