Author Topic: SYE  (Read 7065 times)
black99tj
SYE
« on: November 02, 2006, 08:35:00 AM »
Has anyone bought the hack and tap SYE from Rubicon express? It's a lot cheaper, and I am thinking with a four cylinder the added strength of a new tail shaft is not that important to spend $150 more on. I believe with this SYE, a different type of drive shaft coupling is needed, similar to a ford. Any experience with this?
j-freak153
SYE
« Reply #1 on: November 02, 2006, 05:35:36 PM »
ive heard that they tend to leak quite a bit....
go for the gusto, get the HD SYE....
lutzke21
SYE
« Reply #2 on: November 02, 2006, 05:51:25 PM »
I've had mine for a couple years now, never had any problems with it.
How does it leak?  It's a "hack and tap"...
wrangler387
SYE
« Reply #3 on: November 02, 2006, 08:43:51 PM »
I havn't heard many complaints about them, mostly positive reviews. Those PORC HD SYE have been getting good reviews also, and those are relatively cheap. I know i've seen used hack & taps go for real cheap.
SYE
« Reply #4 on: November 02, 2006, 09:18:23 PM »
Quote from: "j-freak153"
Great job of posting what you 'heard' with facts to back it up.  On a TJ, the H&T uses the stock rear output housing and seal, so it's no more likely to leak than the stock configuration.
I've had a H&T for a few years now, using a TJ mainshaft and tailhousing on my YJ's transfer case.  No problems.  Biggest weakness over a HD SYE is the stock TC mainshaft, and how often do those break?
You will need this: www.rockforddriveline.com/Shopping/R2-21-1229.asp to attach a shortened TJ or XJ front CV driveshaft to the RE H&T.
black99tj
SYE
« Reply #5 on: November 02, 2006, 10:06:43 PM »
Thanks for the information guys. Sounds like a good deal to me.
SYE
« Reply #6 on: November 03, 2006, 12:16:59 AM »
Quote from: "black99tj"
I would heavily consider the PORC HD SYE for $185 w/free shipping.  By the time you do the H&T and buy the appropriate CV flange to mate to it, you're pretty close to the PORC price.  Not to mention the HD SYE is an inch or two shorter than the H&T allowing for a longer driveshaft.
might4banger
SYE
« Reply #7 on: November 03, 2006, 08:39:58 AM »
I snapped the stock mainshaft in my transfer case, so I was forced to replace the shaft... I went with the JB SYE kit bacause the shaft is stronger. Only like $200...
From my experience, I would not do a hack and tap.
SYE
« Reply #8 on: November 03, 2006, 09:04:08 AM »
What were you doing to break the mainshaft?
I've replaced one in another jeepers transfer case, and he was jumping the jeep so it is unusual.
Guardian7
SYE
« Reply #9 on: November 03, 2006, 09:25:54 AM »
I am doing an Advance Adapters SYE with a Woods driveshaft today and will post pics when done.
might4banger
SYE
« Reply #10 on: November 03, 2006, 03:26:19 PM »
Quote
I was climbing a huge hill er.. small mountain... hit some rock embeded in the face and compressed the rear HARD. Busted off a bumpstop, broke off the shock mount from the axle, and nearly $hat myself... :shock:
Here is a pic of my budies Rubi at the base:
SYE
« Reply #11 on: November 03, 2006, 06:34:48 PM »
Quote from: "might4banger"
Rear driveshaft too long?
might4banger
SYE
« Reply #12 on: November 03, 2006, 08:32:17 PM »
It was more of the combo of losing the bumpstop and full compression of the rear suspension.... sunk it deep.
Guardian7
SYE
« Reply #13 on: November 04, 2006, 01:11:12 AM »
We finished my friends SYE & Woods Drive shaft today and here are some pictures we took during the process. As a complete kit it's Cost was $525 from Tom Woods.
SYE
« Reply #14 on: November 04, 2006, 02:27:28 AM »
PORC SYE and shortened front shaft run about $300 :shock:
