Author Topic: Fuel System questions... fuel cell install. need pump  (Read 1957 times)
Erik
« on: November 26, 2006, 07:32:36 PM »
does anyone know what the fuel pressure in the stock 89 2.5 Throttle Body Injected's fuel system is?
I know the engine requires about 14 psi.... but IF you had a pressure gauge on the fuel line what woudl it read? 20ish? 30ish? etc...
the multiport engines require about 40 psi of fuel pressure and when testing a fuel system on one of those with a gauge i heard it will read near 90 psi??
long story short, i need a pump for my fuel cell and i want to make sure the 18 psi carter i'm planning to get will be enough.
http://store.summitracing.com/partdetail.asp?autofilter=1&part=CRT%2DP4601HP&N=700+115&autoview=sku
plan to use this on my 1989 TBI 2.5 with my fuel cell... will have it mounted under jeep to help with flow.
Erik
« Reply #1 on: November 27, 2006, 04:51:37 AM »
nobody knows if that pump will work good for me?
superman1456
« Reply #2 on: November 27, 2006, 06:14:58 AM »
to be honest with you i dont know what to tell you. i just use in tank pumps cuz they are better. they run cooler and are quieter. try posting this question here http://www.hesco.us/forum/ if anyone knows your answer some one here will. good luck
Erik
« Reply #3 on: November 27, 2006, 06:25:45 PM »
might be more quiet but i'll never hear it over my exhaust or 40" boggers so i don't care about noise....
and whether it runs a little hotter or cooler than an intake doesn't really bother me since they last just as long.
i do appreciate your link though... never been on that forum and i'll surely check it out.
i'll be sure to post up my results so hopefully future 4 banger owners can learn from my experience.
I did order that pump today though... if it works it works.. if it doesn't at least i'll know why.
-Erik
superman1456
« Reply #4 on: November 27, 2006, 10:01:00 PM »
good luck. and i know you will like it there at hesco. if you get a chance look at some of my posts they are quite intresting. agan good luck and keep it real.
Erik
« Reply #5 on: December 01, 2006, 05:14:56 PM »
pump is installed and works great.
thanks guys.
