Author Topic: Wandering and Torque steer  (Read 2354 times)
Gr8Ride
« on: December 10, 2006, 04:37:28 PM »
Folks, I need help here.  I've installed a 2" BB, new stock springs and shocks, a skyjacker adj front track bar, a skyjacker steering stab and a rear rubicon track bar relocation bracket.  I thought the 2" BB wouldn't need anything else but the first thing I noticed was a vibration.  So I lowered the tranny plate - problem gone.  While driving to work I hit a pothole @ 55 and thought everything in the jeep to include my fillings were going to be shaken loose.  So I adjusted my toe in to within 1/8".  Only a very slight wobble now on occasion but once was enough to cure my casual driving habits.  Also noticed when I accelerate she pulls to the left, I mash the clutch to change gears and she wants to dart to the other side.  I lift in traffic and she's going to the right.  Not only that, she's a noticeable wanderer now.  Rotated the tires - no change.  Never had any of these issues until I put the new springs and BB spacers on.  Was trying to do this as cheap as possible but have since added the new front track bar and rear relocator bracket.  Any advice would be a great help.  Only future mods are 31 or 32's.
Tall Boy
« Reply #1 on: December 10, 2006, 10:10:25 PM »
wtf is a 2"bb. I forgot I guess
Tall Boy
« Reply #2 on: December 10, 2006, 10:18:34 PM »
if a bb is a lift kit you should not need the tranny case drop kit. Check your steering damper.
 This is about the 20th time I have heard of Jeepers having this problem , and I swear it is too dang funny to hear of them flying all over the road, and the death wobble comes up. I have never touched my track bars or stab bar. Somebody says it is the track bar bushing I think everytime I read about it. Either that or the stabilizer bar bushing, or control arm bushing.
My steering damper made my front tires wobble like crazy when I hit a bump, prior to r&r.
dunklervogel
« Reply #3 on: December 10, 2006, 10:32:45 PM »
2'' BB = budget boost = coil spring spacer lift
Gr8Ride
« Reply #4 on: December 15, 2006, 10:29:44 AM »
Anybody have any solutions?  Please note all I have done when assisting.  Thanks.
« Reply #5 on: December 15, 2006, 10:22:13 PM »
Anytime you change the characteristics of the suspension, lift or lower, you also change the geometry of the alignment referenced to the vehicle. Rather than think a 2" lift doesn't do anything, think of a 2' lift. The farther you bring the suspension away from the frame, the more you change the relationship of the axles, suspension, driveline, etc. Yes, sometimes to many TJs, the 2" spacer lift is nothing, but other times, watch out like you have found out.
First - did you get an alignment after all the install? You have changed the caster on the front axle (the balljoint relationship with vertical) as you have drawn the front axle farther under the frame. You have also changed the steering alignment as you've needed to adjust the length of the drag link.
You got the adjustable track bars to 'recenter' the axles under the vehicle. So hopefully you've done this.
As for the rear, using a riser bracket on the rear axle helps keep the track bar as near stock length/angle, but again, sometimes the tolerances were not in your favor. Just like the front, you've drawn the rear under more underneath the frame. Most remedy the vibration by lowering the skid plate, but this in turn causes binding in the t-case shifter as it uses the floor as a mount. Lowering also hinders the recognition of replacing worn joints in the very short rear ds.
For remedies, ??? Alignment should work out some of the 'darting'.
For wandering, difficult to say, but make sure all your bolt/nuts are tight. Maybe the parking brake cable(s) need adjustment.
For vibration, your pinion should be pointing at the bottom of the tcase and not straight at the end of the shaft. Your axle rotates upward under acceleration. For the front, not a big deal for the spacer lift as the front ds is so long. Besides, the front has an elongated bolt for caster. But for the rear axle, the next remedy is to add adjustable control arms. You can rotate the pinion upward by lengthening the upper or lower arms. Some choose the upper first rather than the lower. Once you get arms, I'd remove the skid plate drop. You loose the lift benefits by lowering something you've lifted, especially something that big in the middle.
Take a look at these and hopefully this will remedy your situation before you get bigger heavier tires (and wheels).
