Author Topic: Spring Rates  (Read 1770 times)
Spring Rates
« on: December 22, 2006, 11:53:11 AM »
Seen this on another board, thought it might be helpful.
Quote
Spring Maker .......Lift .........Rate Front (lbs/in) ..........Rate Rear(lbs/in)
____________________________________________________
Tuff Country ....... 2.5 .............205 ....................................255
BDS ....................2.5 .............299 ....................................299
Old Man Emu .......2.5 ..............185 ...................................208
Black Diamond .....3.5 .............240 ....................................250
Waggy (7leaf front) 2 ..............210 .....................................---
Pro Comp...............4"..............287....................................228
RE........................4.5".............210....................................224
Notes:
*The OME springs speced are J1R and J1R 4 leaf and 5 leaf accordingly.
*Spring rate is per pair unless otherwise noted.
Guardian7
Spring Rates
« Reply #1 on: December 22, 2006, 12:08:25 PM »
I can see why Procomp was so stiff on my old YJ, the rear had 4 leafs and the front had 5 so I pulled a leaf out of the front making it much better. Did you see spring rates for coils?
Spring Rates
« Reply #2 on: December 22, 2006, 12:36:08 PM »
No, only had em for us YJers.
Spring Rates
« Reply #3 on: December 22, 2006, 02:57:12 PM »
wow no mater why i have a stiff ride... i have the BDS lift well at least i wont have to worry about sagging as soon. .
Tall Boy
Spring Rates
« Reply #4 on: December 22, 2006, 08:51:27 PM »
:popcorn:
