Author Topic: Advance Adapters AX15 to Jeep 4 Cylinder Adapter Plate  (Read 3421 times)
Guardian7
« on: December 28, 2006, 03:27:24 AM »
Paso Robles, CA - Due to bigger tires and lower gearing, the AX5 becomes the weak link in most late model 4 cylinder Jeeps (YJs & TJs).  Advance Adapters is proud to introduce an adapter plate to mate the larger AX15 Jeep 6 cylinder version transmission to the stock 4 cylinder bellhousing.  This kit works for both internal and external hydraulic applications and upgrades both the NP231 & NP207 to a 23 spline input.  This kit also fits the Atlas transfer case.
yellowta
« Reply #1 on: December 28, 2006, 07:00:36 AM »
But isn't it MUCH cheaper to just get a bellhousing from a late 90's 4 cylinder dodge dakota? Same motor w/ an ax-15 and all? :wink:
wrangler387
« Reply #2 on: December 28, 2006, 10:05:27 AM »
^ i'd imagine so... thats what i'd do if i were in the market for a ax15. I was going to do a ax15 swap, but found a rebuilt ax5 for too cheap to pass up lol.
Guardian7
« Reply #3 on: December 28, 2006, 12:42:12 PM »
It takes more than just a bellhousing to adapt an AX15
wrangler387
« Reply #4 on: December 28, 2006, 01:20:22 PM »
yes it does... but i bet that adapter isn't priced to cheap. That is all i was talking about.
Guardian7
« Reply #5 on: December 28, 2006, 01:33:09 PM »
I am currently working on the conversion which requires; changing the bell housing, changing the input gear on the NP231 to a 23 spline, machining a custom pilot bearing, replacing or modifying the driveshafts, modifying the trans mounting, changing to a 10 spline clutch, changing the shifter linkage, and changing to an external slave cyl depending the year. Time and cost?
After a call to AA they quoted $450 for adapter, $190 for 23 spline NP231 input gear, $24 for new shifter linkage, total $600-$650 may vary slightly depending on year Jeep you have.
wrangler387
« Reply #6 on: December 28, 2006, 05:20:17 PM »
If i were you i'd look for the dodge bell housing and ebay for the input shaft, or just switch to a new to you 23 spline transfer case and sell off your 21 spline case. Good luck on the swap, keep us updated on your progress :thumb:
Tall Boy
« Reply #7 on: December 30, 2006, 10:33:41 PM »
I called "Midnight Auto" wrecking yard in San Bernardino and they put my request on their computer board and found me an ax 5 w/30,000 miles for $600 like three years ago. But I realized that it was not my tranny, but me, racing like it was a porshe grinding gears and all,screwing my dog teeth. Other than that 4wd hardware has parts for the tranny I think. I have never messed with the internals of a tranny though.
kidwired
« Reply #8 on: January 07, 2007, 06:16:59 PM »
do you have a PN or link for that? I cant find it on their site.
Guardian7
« Reply #9 on: January 07, 2007, 11:03:40 PM »
The AA kit new and not listed on their site, I had to call them for the prices.
Enjoi
« Reply #10 on: January 11, 2007, 03:19:38 PM »
oh wow, learned something new today. AA is from Paso, 10 minutes away from where i grew up  :P
