Author Topic: Clutch Problem  (Read 1620 times)
estepjw36
Clutch Problem
« on: January 16, 2007, 12:23:37 PM »
I have a '93 2.5L wrangler and I am running into a problem with my clutch losing pressure.  The clutch will not engage until about an inch from the floor. I am not losing any fluid, and already have replaced the slave cylinder awhile back.  Wondering if it could just have air pockets in the line, and could simply bleeding the line help.  Any input would help.
tommygp
Clutch Problem
« Reply #1 on: January 16, 2007, 01:07:29 PM »
The master cylinder is probably bad.  It's very common to replace the slave cylinder and have the master fail shortly thereafter because the master cylinder's diaphram is weaker than the slave cylinder's due to age.  It usually leaks inside the cab, on the firewall above the pedals.  Sometimes is doesn't really leak much, but the fluid still isn't moving much because of the weak diaphram.
Your symptoms sound identical to mine and about 3 others that I know of who all had the exact same sequence of events.  Each time ended up being the master cylinder.
I found out later that you can buy a pre-bled master/slave/line combo that replaces the entire thing for about the same as replacing those individual components.  They all fail about the same time, and replacing just one typically causes the others to fail.
Clutch Problem
« Reply #2 on: January 16, 2007, 04:36:44 PM »
Still, bleeding the line should be your first step.  You might save some money or maybe not, in the long run.
tommygp
Clutch Problem
« Reply #3 on: January 17, 2007, 07:50:07 AM »
Good point.
estepjw36
Clutch Problem
« Reply #4 on: January 18, 2007, 01:55:17 PM »
Thats what I figured, thanks for the input, After I bleed the line I'll keep yall informed. Hopefully this is all it will take.
