Author Topic: Split Second FTC1 questions  (Read 2065 times)
kenny kustom
« on: January 17, 2007, 02:48:25 PM »
Anyone know anything about the tuning of the FTC1 ? I am looking for a good basemap or a map that someone has tuned for boost.
wrangler387
« Reply #1 on: January 20, 2007, 09:10:37 PM »
Good luck finding someone running that. You're best bet is to contact split for a basemap and then tune from their. I don't really know anything about that product. That completely controls ignition also correct?
wrangler387
« Reply #2 on: January 28, 2007, 12:02:13 PM »
any luck with split second? if it is fuel only with only timing retard it should be pretty easy to tune.
kenny kustom
Re: Split Second FTC1 questions
« Reply #3 on: February 07, 2007, 08:01:23 PM »
Its in and it runs like a dream  :hitit: Its pretty hard to complety tune without a wide band o2 sensor and an air/fuel recorder  $$$$$$$$$$$$$$$$..im going to leave it alone till spring till i can get it into a shope that can tune it and dyno it at the same time.....
wrangler387
« Reply #4 on: February 08, 2007, 03:26:28 PM »
haha yea you definately need a wideband o2 sensor. The software with the splitsecond doesn't datalog? if so, that definately makes it harder.
kenny kustom
« Reply #5 on: February 08, 2007, 07:02:20 PM »
It does data log, but i dont know how to inturprit the results....
wrangler387
« Reply #6 on: February 09, 2007, 03:51:32 PM »
Does it display the afr results in volts?  What all does it datalog? Map, rpm, iat, clt, afr etc.??
« Last Edit: February 09, 2007, 03:53:04 PM by wrangler387 »
