Author Topic: Which Locker?  (Read 7370 times)
chrisfranklin
Which Locker?
« Reply #30 on: February 05, 2007, 01:31:50 AM »
Quote
Most of the axle breakage I have seen are Dana 35 rear with Detroit Locker and a 4.0L which has more torque than a 4banger.
Yeah Mark, every broken D35 photo I've ever seen is usually showing a rig with 33" tires, probably locked in the rear only, 4 or 6 cylinder (but likely 6).
This all makes sense.  Somebody buys a Jeep (likely 4.0) and they want a lift and big tires.  So they get set up with that and take it off road.  Traction still suffers so they ask around about a locking differential.  Everybody says lock the rear first.  So, they lock the rear.   Then, they throw it in low range, take it off-road, end up unweighting the unlocked front so its just the rear that has traction.  The rear end slips a little on dusty rocks before getting a grip and "snap."
I dunno about stopping D35 axle "tube" bending, but I speculate that chances of outright stock axle breakage in the D35 could be greatly reduced by making sure your Jeep's front end always has traction off road.  Lock the front, if you lock the rear.
I run a locker in the front, not the rear.   What sucks is, I could probably end up having an axle snap in the front if my rear end loses traction.  I think you need to have front and rear lockers and that the D30 probably isn't any better than the D35 in terms of "snappage" vulnerability using a single locker  - small tires and the 4 banger are probably the only thing keeping my front axles in tact so far  :lol:
Guardian7
Re: Which Locker?
« Reply #31 on: February 14, 2007, 12:20:05 AM »
I still feel a rear locker offers better traction when climbing because most of the vehicle weight is on the rear meaning that the rear has more traction. Some of my buddies have put Ford 8.8 rear ends on their YJ's and a Detroit Locker with great results. This seems to be strong enough to handle 4.0L and 35 inch tires with no problem and they can be found for about $300 fairly easy. Last weekend I went wheeling with another friend who currently has an OX Locker in his front end only and we had very poor traction climbing loose rocky hills while my TJ climbed them without even slipping a tire. I currently have a rear locker in my D35 and 33" BFG's. Another huge traction issue is suspension flex, keeping those tires on the ground firmly makes all the difference in the world when climbing hills and preventing the bounce effect with a good set of shocks plus an antiwrap system on leaf springs. The first time I pulled my sway bar links was a truly amazing experience and I wanted more! Both my previous YJ and current TJ run 33" tires and never snapped an axle but most people agree 33" is as big as you can go on the stock axles. The XJ in the picture has 35" tires and a 4.0L and keeps breaking axles when we go wheeling but he trailers it to the trail head expecting carnage.
