Author Topic: 32s on an unlifted YJ?  (Read 6611 times)
chrisfranklin
« on: February 11, 2007, 04:39:49 AM »
Searched around here and found a few posts on cheap ways to accomodate larger tires.
I've seen the JP magazine piece where they managed to shoe-horn 35" tires on an unlifted TJ by performing major surgery on the body.  You can pull off  big tires on a TJ, no lift, if you are willing to get aggressiv with the Sawzall.
Here's my question:  On a YJ, you think you could squeeze in some more modest 32's without a suspension lift by doing a 1" shackle lift, 1" poly body lift, TJ flares and some reasonable fender-trimming? Would these 32s work on the stock 15x7 factory steel wheels?
lanulos89
Re: 32s on an unlifted YJ?
« Reply #1 on: February 11, 2007, 06:41:33 AM »
if you get rims with diff. back spacing you will probably be good, but with stock ris i believe you will be pushing it.  but with the 2"inches of lift, and a lot of trimming i see no reason why the 32's wouldnt fit.
« Reply #2 on: February 11, 2007, 08:58:54 AM »
other than backspacing they should fit with the tj flares and 2 inches of lift.
« Reply #3 on: February 11, 2007, 12:59:08 PM »
I don't think wheel backspace is the way to go.  All that will do is help keep teh front wheels from rubbing at full lock.  You can correct that by turning the steering stops.  Although, you will want to run a 32x11.5R15 on an 7" or 8" wide wheel.  Keep in mind that in CA you don't want your tires sticking out.  Some LEO's don't care while others are very picky and will ticket you.  As for 32's, you could fit them if you do some trimming and convert to TJ flares.
When I ran 32's I had 3" and then 4.25" of lift.  I used it all and with 3.75" BS, my tires rubber the stock flares but cleared everything without touching the stops.  The tires were about 4-5" past the flares.  Lift shackles of 1" will change the front end geometry and give you less caster which is bad and could cause wander.  It will also raise the front pinion and that will mess up the U-joint angle for the worse since the two yokes won't be in phase anymore.  You could shim the axles back with degree shims which would correct the problems listed above. Honestly, I'd rather run some beafy 31 MT's then some mild 32's, especially, if you're looking to get some oversized car tires.
rwing1
« Reply #4 on: February 11, 2007, 01:20:06 PM »
I run factory 15x7  5-spokes off of an XJ with my 31's and they do rub the springs at full lock but otherwise fit without much else... the side lugs of my BFG MT's just barely stick out past the flares maybe 1/2".  I for one wouldn't want to run bigger than my 31's without gears to get the RPM's back up there :biggrin:.  Living on my budget means keeping away from the snow-ball effect of going to bigger tires. But with TJ flares(or tube fenders) I would/will be awfully tempted to try bigger!
chrisfranklin
« Reply #5 on: February 11, 2007, 04:00:32 PM »
The Revos are basically street tires classified as AT.  But, da$% they are good - don't know if its the tread pattern, compound or what
Still, I could see doing some 31" Mickey Thomson Bajas.  I've used BFG before, but it was just their "Long Trail" model and those were pretty awful in every condition. Perhaps the MTs are better
« Reply #6 on: February 11, 2007, 05:18:04 PM »
I'd look at some real tires. :blbl:  BFG KO AT's are good tires and will last a long time (4-60K Miles or more) while still being a good offroad tire.  If you want a more agressive look but still want good tread wear then look at the KM's.  Long trails are working truck tires and are designed for load carrying on a work truck.  MickeyT's Baja's won't wear as good as the BFG's and most of their line are bias belted.  Revo's are street tires.
On the upper end, there are the Goodyear MTR's.  These are not MT's.  They work quite well on and do very well offroad.  Toyo's are supposed ot be good too BUT they are large tires and I don't think they have anything under 33" and no less then 13.5" wide.
chrisfranklin
« Reply #7 on: February 12, 2007, 12:30:12 AM »
Yeah, I probably can't go wrong with 31" BFG MTs.  So what do you say to fit those
-TJ flares, cut the body?
-small shackle lift & 1" body lift?
I'd run the stock 15x7 factory wheels and I am already using 1.25 inch aluminum spacers all around, so there's no rubbing on the springs
« Reply #8 on: February 12, 2007, 12:44:02 AM »
With spacers you should be fine on the BS.  That would be around 4.25" BS which is a good number.  You could do TJ flares, 3/4" shackle and or a body lift.  If you did all three, that will give you a lot of room without putting all your eggs in one basket so to speak.  You shouldn't have steering or driveline issues since you've spread the lift around.  Since 31's can fit on a stock YJ you could even run them as is then see where you need to clearance them.  If you did all three you'd be pretty well set up.  With good tires and the locker, you should be ready for most trails out there.
JeepManMarc
« Reply #9 on: February 12, 2007, 01:16:37 AM »
My buddy has a stock YJ with stock flares some wider american racing wheels and 32 by 11.5 A/T's , will rub every so often but he hasnt had any issues at all, no lift as far as I know, he bought the Jeep this way.
chrisfranklin
« Reply #10 on: February 12, 2007, 04:33:19 AM »
JeepManMarc, so that Jeep YJ in the photo is the friend's Jeep you mentioned - the one running the 32's, no-lift?
« Last Edit: February 12, 2007, 04:37:35 AM by chrisfranklin »
JeepManMarc
« Reply #11 on: February 12, 2007, 09:49:45 AM »
Yes, at full flex it will rub the flares slightly but not enough to cause any harm as of yet and we have been wheeling it pretty hard.  If it were mine and I wanted to stay with 32's I would probably do a 2 inch lift because it would look a little better, but as it sits it functions just fine.
« Reply #12 on: February 12, 2007, 10:06:06 AM »
I assume that's with the trackbar and the swaybar still on.  I can see the tell tail sign of the tires rubbing the flares and that's not a lot of room there.  I know I was rubbing the flares with 3" of lift and the trackbars plus the swaybars still on.  Take them off and the tire really rubs the flares and eats the fender.
Tall Boy
« Reply #13 on: February 12, 2007, 01:05:35 PM »
If you are worried about power, get the turbo, do an engine swap, or lower geared tranny/differential. I have seen rubicons w/ 35's have a top speed of 65 with stock gears. I know I can do alot with 31" tires and skid plates from experience, 33 and 35's will do the hardcore stuff, I have done hairy stuff with 30's too. If I get a turbo, or regear to 4:56 I will get 31's or the interco 32x10.50x15's and stop there. Too much meat on the tires takes away the power fast.    Aluminum rims are not as strong as steel, but i have done some hillacious stuff on them without problems other than scratches, and aluminum gives back alot of power lost to turning those steelies. Steelies take alot to get to momentum speed, and keep the momentum going better than aluminum do, but I am unsure if it is enough to matter. I noticed a big difference switching to aluminum rims though.
lanulos89
« Reply #14 on: February 12, 2007, 01:52:22 PM »
dunno marc, from the pictures, they dont look like stock jeep shackles, i kno its hard as hell to see but look closely, maybe has a small shackle lift, if not like jeffy said thats with track and sway bars.  with them installed a yj will barely flex.
