Author Topic: Rattle, hopefully not of the death variety  (Read 5408 times)
Andini
« on: August 23, 2005, 09:27:35 PM »
I just obtained a 1990 YJ with around 212,000 on what I think is the original 2.5. It pulls strong, and under load doesn't make any rattles that I think are uncommon (although the water pump is starting to make a "replace me" noise) My question comes about when I unload the motor i.e. disengage the clutch. Sometimes (not always) I get a big rattle, which I can't locate, it's either in the rear end, or in the motor. I can't locate it because it generally happens at low speed, and tends to be accompanied by a motor stumble. Any ideas what might be making this happen.
Gears, tires etc. are all stock
Thanks for the help
« Reply #1 on: August 23, 2005, 10:40:25 PM »
I'd check the engine mounts to see if they are still intact.
