Author Topic: Gas Mileage Thread  (Read 186796 times)
0 Members and 12 Guests are viewing this topic.
st.chevrolet
Re: Official Gas Mileage Thread
« Reply #75 on: March 29, 2008, 02:24:10 PM »
'98 TJ
2.5l (140k miles)
ax-5
30/35 w/ 4.10's and open
34" LTB's on 15x8 black steelies
mainly 4th gear try to keep the motor around 3k RPM
avg 15-16 MPG on 87 oct
I was just curious as to why you would want to keep your engine at 3000 RPM, at that RPM your jeep would use more fuel.
Mr_Random
« Reply #76 on: March 30, 2008, 01:28:51 AM »
Yes, but with the highest torque. The 4cyl usually peaks around 3000RPM in torque, and is therefore most efficient in the comparison between incoming fuel/air and output torque. If I drive 25mph, with the engine in 4th gear, and around 1700 RPM, I get worse gas mileage than running in 3rd gear, at 2600 RPM or so. (just as an example, I don't exactly remember which RPM goes where, as I HATE driving 25 and do it as little as possible).
Actually, because of the nixed cat on mine (PO did it, not me), my whole curve moved up (but gained an HP or two) and it's most efficient for me to run going way too fast for my driving brick, with the RPMs up even higher than most 4cyls.
When cruising fast, 35-4000 RPM is the best for me, I stay in fourth going up to ~75mph, until either my vibrating foot or my sense of well-being makes me shift to fifth (and this is with 215/75r 15's!, wait until I get some 30's or 31's!).
Mr_Random
« Reply #77 on: March 30, 2008, 01:31:47 AM »
Appearantly no edit allowed... 14mpg all-around town (stupid high idle EATS GAS), 20mpg mixed/county driving, ~25 highway (haven't done this for a while though, will do again soon).
howler
« Reply #78 on: March 30, 2008, 07:04:39 AM »
2006 TJ
Avg. 18.5 mpg
I usually drive short trips
2.4 L
3.73:1
6 speed manual
31 inch MTR's
No real mods yet, hoping you guys can help with that.
Rob the plumber
« Reply #79 on: March 30, 2008, 12:23:19 PM »
4000 rpm cruising down the freeway? Holy crap.......
Mr_Random
« Reply #80 on: March 31, 2008, 01:52:48 AM »
holy crap as in high? Yeah, that's when my speedo (stops at 85) is bouncing around past it's top end, I've only done it two or three times though... and when my XJ was stock height... I'll probably never try it again...
With taller tires my RPM's should drop, but I'll probably never go the same speed, so I'll be happy.
BarneyJeep
« Reply #81 on: April 03, 2008, 07:06:44 PM »
update: 170mile trip this weekend... cruise set @ 66mph (according to GPS), in fourth gear @ 2850 RPM... 16.1MPG no drafting
« Reply #82 on: April 16, 2008, 02:14:31 PM »
I agree with keeping the 2.5 at 3000rpm's, mine cruises best about there.
Keep in mind it takes the 'puter a good while to adjust to performance mods.  My mileage went way up a few weeks after installing a 62mm throttle body.  Takes a certain amount of key or warm-up cycles to relearn.
« Reply #83 on: April 16, 2008, 05:30:18 PM »
With all the mods I have done and the same driving style, I've seen my mpg increase from 14.4 to 15.8; I still want to break the 16mpg barrier, though, so I will try the 3K rpm and see how that goes.
mpyusko
« Reply #84 on: April 27, 2008, 12:45:39 AM »
1997 TJ 4cyl, 5pd, 145,000 miles.
Worst ever:  14.5 towing a ~2000 lb trailer. (Adk's)
Best ever:     19.5 towing a ~2000 lb trailer. (Rocketry gear)
Usually, puttering gives me 16.5 and highway up to 17.5.
(My TPS died once at Paragon and I drove 4.5 hours home getting 15 MPG)
Rob the plumber
« Reply #85 on: April 27, 2008, 03:34:43 AM »
I don't know how much yet, but my mileage definitely increased after installing the turbo. it looks to be about 3 mpg or so. I guess not having to use half the throttle maintain 60 mpg helps.
TrailsLessTaken
« Reply #86 on: April 30, 2008, 09:26:24 AM »
around 8-10 MPG,
Tranny - AX-5
Engine - 2.5
Tires - 35X12.5X15 Wranglet mtr
Gearing - 4.10s
Speedometer Calibration - No
Engine Mods - air intake, flowmaster exhaust,
120,000 miles and the mileage doesnt change much no matter if its city or highway, but i think the motor may be about shot
Rob the plumber
« Reply #87 on: May 01, 2008, 06:09:07 PM »
around 8-10 MPG,
Tranny - AX-5
Engine - 2.5
Gearing - 4.10s
There is something wrong there. You should be around 15 mpg.
TrailsLessTaken
« Reply #88 on: May 01, 2008, 08:12:17 PM »
when i got the jeep about 5 or 6 years ago it used to be alot be alot better but just the last year or two its started getting worse and i bought a new truck and just put it on the back burner but now i have the money to finally get the engine rebuilt that way i can finally get back out on the trail
« Reply #89 on: May 02, 2008, 05:10:12 PM »
Bad O2 sensor?
