Author Topic: TBS question  (Read 3018 times)
dadickster
TBS question
« on: March 18, 2007, 09:39:53 AM »
I have a 94 yj that I am installing  a 4.0 TB & TBS. I am getting the AIRAID TBS. Do I need the TBS for a 4.0 since I will have a 4.0 TB, or for the 2.5 because that is the engine? Thanks
Re: TBS question
« Reply #1 on: March 18, 2007, 10:39:19 AM »
Doesn't matter, they are the same. Just get one with the same bore size as the TB you are getting.
Re: TBS question
« Reply #2 on: March 18, 2007, 01:15:05 PM »
If I was buying one I'd probably go with the smooth bore ones on ebay that sell for under $50.
dunklervogel
Re: TBS question
« Reply #3 on: March 18, 2007, 02:04:56 PM »
Are the spacers with a helix/spiral bore just bs or does it actually do something?  Always wanted to ask that.
Re: TBS question
« Reply #4 on: March 18, 2007, 05:03:38 PM »
Well, seeing that a commercial TBS like the Poweraid, JET, Hesco, etc... cost around $70 and up and the ebay ones are $50 and under, I would save my $20.  The bore on the TBS with the cuts are usually smaller then the TB.  The ones with a very shallow spiral don't really have enough surface area to produce a swirling effect and the ones that do reduce the size of the bore.  Then you have to get that swirling air through the intake and through the head to the valves.  I don't think the swirling will get that deep into the intake either.  It has to take a 90* turn at the bottom of the intake and get to the head before it's able to mix with the fuel.  That's a lot of swirling.
With that said I have a Poweraid but I bought it when no one else made them and they didn't even have an official 2.5L spacer.  I should probably hone my TBS.  Maybe one of these days.
lanulos89
Re: TBS question
« Reply #5 on: March 18, 2007, 06:09:15 PM »
wasnt it proved that tbs rob you of power, i kno b4 my bigger wheels, i cldnt get my tires to spin with my tbs on, and when i took it off i got em to spin,  that was with the 2.5 tb i dunno does the 4.0 tb and spacer not rob the power away?? sry dont mean to hijack
Tall Boy
Re: TBS question
« Reply #6 on: March 18, 2007, 07:52:20 PM »
 :uhoh:  People stare at you when you drive by though  :uhoh:. They give you the look like "   what the hell is wrong with that guys car "  .     :thumbsup:
« Last Edit: March 18, 2007, 07:54:10 PM by Tall Boy »
lanulos89
Re: TBS question
« Reply #7 on: March 18, 2007, 08:13:40 PM »
haha yea or you tell em its the super charger spooling up, since i put on my 4.0 tb mine whistles, haah its pretty cool tho so im not concerned
Re: TBS question
« Reply #8 on: March 18, 2007, 09:02:45 PM »
I saw an improvement with my TBS.
Offline SKI BOY
Re: TBS question
« Reply #9 on: March 19, 2007, 05:25:57 AM »
Some of the "generic" ones on ebay that I've seen do  have  a different bore size for the 4.0 vs. the 2.5. Ask the seller  what the size is and get the same as the 4.0 TB, so you don't add restriction!
Ski Boy
  • Poseur Extraordinaire®
Re: TBS question
« Reply #10 on: March 19, 2007, 07:01:37 AM »
I like TBS....they show re-runs of Seinfeld and other good shows.... :whistle:
Offline dexetr30
  • 4BangerJP.com® Donator
  • Aloha Mr. Hand!
Re: TBS question
« Reply #11 on: March 19, 2007, 09:00:09 AM »
Yeah, mine does this too. I thought I was the only one. I kinda like the sound of it.
lanulos89
Re: TBS question
« Reply #12 on: March 19, 2007, 01:23:00 PM »
good one moz
Tall Boy
Re: TBS question
« Reply #13 on: March 19, 2007, 07:53:24 PM »
like vrocket yeeeaaah!  :biggrin:
