Author Topic: Need bumper bolt size.  (Read 1288 times)
Offline dexetr30
  • 4BangerJP.comŽ Donator
  • Aloha Mr. Hand!
« on: March 19, 2007, 07:53:30 AM »
I was crawling around under the Jeep this morning and noticed the mounting bolts on the bottom of the bumper are m.i.a. Does anyone know what size bolts these are so I can replace them?
bhawkin2
Re: Need bumper bolt size.
« Reply #1 on: March 19, 2007, 01:36:40 PM »
I know the front bumper bolts are 1/2x13 atleat thats what I put in mine.
« Reply #2 on: March 19, 2007, 02:02:04 PM »
Yes, standard 1/2x13. The heads are a little different. If you are going to use a winch, use different head bolts. Most thieves just check to make sure you don't have lock down. Then grab their standard ratchet wrench and socket. They probably don't have the mind to pull multiple size sockets. Don't forget to use antiseize on them also. Helps with the removal when necessary.
Mine are SAE and Metric.
Offline dexetr30
  • Aloha Mr. Hand!
« Reply #3 on: March 20, 2007, 06:33:38 AM »
Thanks guys. I don't have a winch yet but I'm working on it.
