Author Topic: replace shackles with new lift kit or not ???  (Read 2395 times)
alandchris
« on: March 27, 2007, 10:06:37 AM »
getting ready to put the lift kit on in a week or two - the stock shackles are not bad - but would you recommend changing them while there 1/2 apart anyway ?  I'll only do casual trails (not heavy rock crawling)
it's a fabtech 4 inch lift -
if replacement - what would you think - stock height shackle / 1/2 inch higher - don't want any caster/camber issues - and what brand would you prefer
thx
Re: replace shackles with new lift kit or not ???
« Reply #1 on: March 27, 2007, 11:35:40 AM »
If the new springs are military wrap like most good lift springs, you'll need to use longer shackles.  The stock shackles don't work with a miltary wrap spring.  I think mine are 5/8" lift (1.25" longer than stock)
« Reply #2 on: March 27, 2007, 03:35:12 PM »
have to have them what... i have a bds 2.5 inch lift that says it has military raps and i still used my stocker shackles.. although i would like to get different ones that don't look so weak.
« Reply #3 on: March 27, 2007, 04:12:44 PM »
How much clearance do you have between the spring and the frame?  I'm suprised that the spring eye doesn't hit the frame on full compression.
lanulos89
« Reply #4 on: March 27, 2007, 04:50:19 PM »
yea my kit has military wrap and i always hit my frame, and after front axle is in next project is some bommerang shackles
« Reply #5 on: March 27, 2007, 06:19:58 PM »
ow now i see the problem.. i haven't pushed it hard enough... i guess ill have to invest in a set of these
j-freak153
« Reply #6 on: March 31, 2007, 09:48:20 AM »
yes...nuff said
YJmechanic
« Reply #7 on: April 01, 2007, 05:48:11 AM »
i have bds military and need the shackles too. i use just a set from qtec don't know if they were a specific brand or just hd shackle listing but they are plenty beefy.  i would just warn you against tera revolvers because most people hate them and they are expensive.
chrisfranklin
« Reply #8 on: April 01, 2007, 06:41:25 PM »
Suspension lifts are cool.  But you really have to hunt around for a hard trail to need one + big tires.
There's probably 60-70 OHV trails in So Cal and only maybe the hardest 7 or 8 of them really have the rocks/terrain that call for a lift and larger tires (33-37") for clearance sake.   And with half of those, you are winching yourself up the whole time and would probably need an additional 5-$10,000 buildup - 4:1, new rear-end, etc :lol:
With everything else here, though, you are good with no lift, 29-31" tires and maybe a locker and a couple of suspension mods (no track bars, sway discos), as long as you have a little armor.    The Wranglers are extremely capable stock with just a few cheaper mods for better OHV trail negotiation.
If you really need a lift for off-road use, then you probably need a heck of a lot more than just the lift, unless its all just for show.
« Last Edit: April 02, 2007, 07:38:13 AM by chrisfranklin »
