Author Topic: trac bar removal  (Read 2211 times)
alandchris
trac bar removal
« on: March 31, 2007, 08:30:29 PM »
95 YJ -
putting the lift kit in - on jack stands - first direction says to take the lower nut/bolt off the trac bar.
trac bar won't come off- PB'd the hell out of the nut on the left side - nut came off - the bolt won't come thru - I hammered the PI$$ out of it - is there a trick to this - or am I just experiencing "rust seizure".  Will torching it help any.  AL
Re: trac bar removal
« Reply #1 on: March 31, 2007, 09:13:56 PM »
Are you planning on reinstalling a trac bar?
I couldn't get any of the bolts to move on mine, just cut the brackets right off the frame as well and cutting the axle mounts.  But that's not a good option if you are planning on running trac bars ;)
alandchris
« Reply #2 on: April 01, 2007, 05:05:52 AM »
keeping it for now
i guess i'll try to loosen the right side to give a little more play and then use my 5 lb hammer and take a few cracks at that bolt on the left side
« Reply #3 on: April 01, 2007, 06:43:09 AM »
You could also try to use a cutting wheel or sawzall to cut the bolt on each side of the trac bar.   Chances are that the bolt is seized in the trac bar bushing and only a whole lot of heat will get it loose.
JWJeeper94
« Reply #4 on: May 06, 2007, 08:48:23 AM »
I'm no old hand but on my long gone 94 I had to take both bolts out and hammer while moving or wiggling it on the frame end.
hope that helps
« Reply #5 on: May 06, 2007, 01:15:01 PM »
I cut the bolt head as well, then I had to torch the bushing in order to punch it through.
