Author Topic: low ratio carrier  (Read 1603 times)
huntingbuck101
low ratio carrier
« on: April 15, 2007, 08:49:18 PM »
I have 4:10 gears now in my 98 TJ and looking at going 4:88 will I need to get a low ratio carrier?  what else will I need to swap them out?
Re: low ratio carrier
« Reply #1 on: April 15, 2007, 09:41:58 PM »
The carrier will be fine, they are 3.73 and numerically higher so 4:10 to 4:88 will work.  I am assuming that you have a d-35 so you will need a crush sleeve and a new pinion seal.
« Reply #2 on: April 16, 2007, 06:04:45 AM »
if i recall correctly 4:88 is the lowest you can go with your stock carrier.. so you'll be ok but with 4:88 but cant go any lower.
