Author Topic: Shim limit?  (Read 1772 times)
Shim limit?
« on: May 15, 2007, 07:29:41 AM »
Is there a reasonable limit to how much a rear axle can be shimmed safely to change the pinion angle?  Thanks
Re: Shim limit?
« Reply #1 on: May 15, 2007, 03:05:08 PM »
I wouldn't think so, as long as they are installed correctly.
wrangler387
Re: Shim limit?
« Reply #2 on: May 15, 2007, 03:07:08 PM »
I run RE 8* steels shims in my rear... i've seen people run 10* and 12* though. Get steel though not aluminum shims. Just make sure the centering pin thingie is long enough to still reach the axle after going through the shim.
Re: Shim limit?
« Reply #3 on: May 15, 2007, 03:38:10 PM »
Less is always better.  You do NOT want to stack shims.  Keep in mind that shimming will bring the pinion up which could cause oiling problems if you raise it too much.  On the front it will throw off your camber which isn't a good idea.
Re: Shim limit?
« Reply #4 on: May 15, 2007, 04:14:53 PM »
Thanks for the input.  I was thinking of about 6 degrees so it sounds like it should be fine.  Will be installing a D44 soon in the '95 YJ with no lift for now but will eventually go with a 2.5 inch lift, maybe in about a year.
Offline supryj4
Re: Shim limit?
« Reply #5 on: May 15, 2007, 06:29:21 PM »
check out the tom woods web sit it will have all the info you need for setting the correct pinion angle so you dont have any u joint problems.
