Author Topic: Pinoin Preload  (Read 2036 times)
Offline 95 Lowbuck
Pinoin Preload
« on: May 26, 2007, 09:01:00 AM »
Just ran in my rebuilt D44 on jackstands.
The Pinoin seems to be running warm.
According to my specs. I should run 25-45 in. pounds of preload.
I ended up with 32.
Does this sound about right?
Re: Pinoin Preload
« Reply #1 on: May 26, 2007, 06:12:47 PM »
I ended up with 32.
Most guy's who run shims for teh pinion preload run then 'goodntight'.  If you're measuring them though, 32 sounds OK since it's between the specs.
Re: Pinoin Preload
« Reply #2 on: May 26, 2007, 07:03:56 PM »
What is your backlash measurement?  Running that too tight will result in warm gears.
Offline 95 Lowbuck
Re: Pinoin Preload
« Reply #3 on: May 26, 2007, 08:52:58 PM »
They call out for .008 - .010 and I wound up with .007 - .010
checking in 3 different places.
Re: Pinoin Preload
« Reply #4 on: May 29, 2007, 07:41:07 PM »
Sounds like a lot for preload, I thought 15lb/in for used bearings and 25lb/in for new bearings was about max.  Maybe I'm mistaken.
You want to make sure there is no drag on the axleshafts when checking preload.
Re: Pinoin Preload
« Reply #5 on: May 29, 2007, 10:02:52 PM »
35inch/lbs is correct if you check preloadof the pinion and carrier bearings when both are installed.
Art
