Author Topic: power steering pump  (Read 2321 times)
tttppp54
power steering pump
« on: May 27, 2007, 07:39:16 PM »
is replacing the power steering pump easy? would anyone recommending to ugrade to an agr pump or just replace with stock?
Re: power steering pump
« Reply #1 on: May 27, 2007, 08:40:30 PM »
what year.. being a 4banger in a 6 cylinder engine compartment there is a lot of extra room to work on it. the biggest thing is having a pulley puller to get the pulley off the pump. otherwise its pretty easy.
Offline Elyod
  • Sedona is red
« Reply #2 on: May 27, 2007, 11:42:45 PM »
Why are you looking at replacing it? I am thinking of buying a high performance pump because i am buying a hydraulic winch (ya, I made up my mind between electric and hydraulic) and i want to be confident in the setup.
Offline dexetr30
  • 4BangerJP.com® Donator
  • Aloha Mr. Hand!
« Reply #3 on: May 28, 2007, 10:04:49 AM »
Easy job. Just have a puller as suggested by chardrc. If your Jeep is fairly stock I'd go with the stock pump.
tttppp54
« Reply #4 on: May 28, 2007, 11:56:03 AM »
the reaso n for replacing is because the current one is going bad and leaking. i have 35's so i might just go ahead and get the agr and maybe eventually get the agr steering box too.
  • Poseur Extraordinaire®
« Reply #5 on: May 28, 2007, 03:23:31 PM »
I have an AGR SuperBox II sitting in the garage waiting to go on....but I was just going to use the original pump.  I may not put it on now until the new axles and wheels go on though....guess I can decide then.
« Reply #6 on: May 28, 2007, 08:44:24 PM »
I don't have any experience with the AGR products but have heard a lot of negative coments about them.  There are a few guys running a Dodge durango or dakata power steering pump instead.
« Reply #7 on: May 29, 2007, 06:09:51 AM »
AGR boxes are craptastic.  Nothing but a poor rebuild on a stock pump, nothing to justify the money they charge for them.   I'm running a stock YJ pump with 35's and it works fine, but if you want an actual upgrade check out http://www.pscmotorsports.com
« Reply #8 on: May 29, 2007, 08:08:08 AM »
Crap, I meant to say box not pump.
